Grading beam and V ditcher for sale
JerryRtilt
JerryRtilt
Before i advertise them elsewhere is anyone interested in a tilting grading beam or a V ditching bucket, both hardly used just been sitting around, used on my 8t Takeuchi, 50mm pins, 290 centres, 170mm dipper width. Located in Kent.
Beam £1200.00
V ditcher £450.00
+VAT, could deliver Kent, Sussex, Surrey.?
Would fit my Takeuchi and im kind of tempted but made a decision to more focus on the 5 ton and 3 ton rather than having stuff for all of them.
welded pins on the beam though Vin :(
bucket's on loose pins .. get the measurement between the cheeks for the beam @Vinpetrol ... might be enough to cut the pins/bosses off inside and pin ends outside - knock the stubs out and bang some new pins in if the cheeks are far enough apart :unsure:
JerryRtilt
JerryRtilt
All looks very doable 👍the bucket actually measures 180 between the bosses, 10 minutes with a grinder will get 185.
The beam has 192 between the cheeks so a bit more work with a grinder and some new pins welded in will sort that 👍.
