one for mogman on his doorstep
suspect it's Ying Tong, but is cheap enough ... once you've been punching holes a drill is archaic ... an equivalent from Alfra or Nitto Kohki would be 10-15 times the price - used to have 4 of these handhelds with powered packs and saved sooooo much time
punch/die sets used to be about 20 quid a pop back in 2010 when I was last buying them .. closer to me and I'd be considering it - so handy and quick -- looks to be a std die size set up so should do 21mm, 'praps 25 dia? will also do slots, squares, keyholes, etc.
and the power pack is a knock out set too
unreal the ying tong prices ..... especially when you consider how far it comes :oops:
Beat me to it.
If never buy chinky stuff secondhand unless I knew the owner....
my little Alfras and Nittos cost me circa £4k each S/hand .. but were motorised packs ... my big Alfra was nigh on £6k -- all 60+ tonners though .. the big un was for punching holes in centre flanges on beams and'd do 24mil in the centre of a 354mm beam .. made the gantry for it and a pair of stands to grip and hold a beam from one flange only, leaving the other flange clear to run up/down full length .... saved hours of drilling/broaching beams
2013-09-07 10.20.55.jpg 2013-09-07 10.21.07.jpg 2013-09-07 10.21.15.jpg Picture_0139.JPG imac 2.JPG imac.JPG
