If they’re 100mm across the ears and 85mm pin centres they’ll fit a Kubota. How wide are the buckets?Was ordered for TB210 wrong, we think 25mm pin maybe Kubota kx36![]()
Sorry I meant to say my machines are the same dimensions, not the same as micks buckets.My case cx16 and kubota kx36 are on 25mm pins and same dimensions
Can you do me a favour, get some verniers and measure the pin centres please? Go over both pins and subtract 25mm.12” 24” Dutch (36)
Either way worksI was always taught to measure from either l/h of one hole to l/h of other hole or vice versa.
The amount of people I've worked with that still can't get the jist of centres are the same edge to edge lolI was always taught to measure from either l/h of one hole to l/h of other hole or vice versa.
The fitter with buckets was on site yesterday, I’ve asked him for a vernier measurement!Not as accurate if you’re using verniers. Best way with verniers, measure the inside of the pins, measure the outside, add together and divide by two. Works best for me.
If anyone wants a manual quick hitch for these, I've got one in the yard. 3 years old, not done a lotMy case cx16 and kubota kx36 are on 25mm pins and same dimensions
I’ve taken the newness off them already, Mick.12” 24” Dutch (36)
Thanks, I bought 2 a couple of years agoIf anyone wants a manual quick hitch for these, I've got one in the yard. 3 years old, not done a lot![]()
Next time just ask we can grind all the paint offI’ve taken the newness off them already, Mick.
