I found myself a tiny loader crane
Bucket on wheels
Bucket on wheels
shall I buy or not :p:eek:o_O
It's as cheap as it's tiny
£ 703034.- GBP
It has 2 winches
telskop parts 9 in the main arm + 3 manual
telskop parts 6 in the jib + 3 manual
At 27.90m can it lift 7600kg.
3 meters behind the back support leg,
can it with full ballast lift 68 tonnes.
Get it bought Frank(y)(y)
P
powercom
Sweet everyone loves a good "lorry loader" !!!!! ,(y)
"look " its even got hitch so you could carry a plank of wood to site on trailer.:LOL:
it is a proper tool, no doubt but what would you use it for? is that designed for a specific application , as apposed to you standard lorry loader ? cost wise it has to be right up there with a telescopic of a similar capacity , I guess low headroom restricted height applications but for vertical use it would take up the same area as mobile crane , and despite the hitch I would not think it would be able to take a load to site as its will be outside construction use regs without a trailer so one of the advantages of taking a load to site with a truck is I guess not possible.
still you have to love the engineering in that
Can you elaborate on what you mean ?
why build it Frank ? ..... it's a beast of a thing and there're plenty of cranes about with superior abilities of a similar size ..... it'd need loads of headroom to use it and Loccatelli do some real nice low headroom, heavy lifters. plus there are other 'lifters' about for low headroom.
the engineering in it is impressive ..... but WHY ???? ;) .... really can't see it has a niche .... if it does it must be a bloody small one :whistle:
Could it be used as an under-lift, for reaching under bridges? I have no idea why that might even be useful but I do know there are MEWPs with that capability (which do make sense).
lots of dedicated under bridge access equipment about for that though
some of which is pretty spectacular gear
these type of things were the fore runners for bridge access
but the loader crane type of gear has become much more popular and is far more easily deployed.
Beauty of the first system though, was that it'd cover a much larger working area and gave better access, without having to be withdrawn from the work point ... was effectively an 'air-bridge' sort of working platform you could climb in and out of, in position.
skip to 6:28 ..... anyone ever seen a loader crane like that before .... obviously pretty specialised i'd guess ... fast though:rolleyes:
saw a feature to start a 'tube vid at a given point the other night .... damned if I could see it for this :unsure::(
ON EDIT ..... it actually worked ... amazed :cool::giggle::giggle:
Jimbo69
Jimbo69
I’ve used something like that before but can’t for the life of me think where 🤔 @Quattromike do you know if they have something similar at Glenfiddich, in the bottling hall?
I've seen similar, fixed in plants/factories/buildings ...... but never one on a vehicle :rolleyes::oops:
Jimbo69
Jimbo69
I think it was something smaller for lifting boxes onto pallets that I used, that does just look like a bigger version.
I’ve been on site 3 times this week but not near the bottling hall for a long time so not sure tbh.
tinydigger
tinydigger
Doesn't someone make a kerb crane on similar principles ??
Yes, it was that self contained unit thing iirc posted on here recently?
yeah probst make one called the jumbo bv it has a petrol power pack to power the suction head for picking up the kerbs. they mount on a telehandler then you can pick up a pallet of kerbs on the end of that. They are a top heavy horrible bastard to try and transport but once on site and working they do a great job. only know about hem cause we had one come in for a customer who was putting a new road in and i had the joy of taking it to site and working on it when it come back lol
Jimbo69
Jimbo69
A firm up here had something like that mounted on a trailer. Never saw anyone use it though as it was a faff to set up and use.
