Hello From Guernsey
G
Guernsey Submarine
Hi All
I make manned submarines as a hobby here in Guernsey Channel Islands. I have a Bobcat T2556 telehandler that i use to move them about.
Im not very familiar with hydraulic equipment, so just looking for some advice on a few bobcat related topics.....
Regards
James
Management
Finally another submarine enthusiast!!
Tidy looking bobcat, what’s up with it? I’m sure it can be fixed…. So long as it’s not 3000ft under the sea somewhere!
bobthebuilder
i have a massey 8925 which is a t2556 ,i know the insides quite well ,if you search ebay there are service disks with a complete parts list with diagrams
G
Guernsey Submarine
Hello Dave
The problem is quite simple I think, and probably really obvious. The handbrake is leaking. So i assume its just blown an O ring in the valve. Ive taken the valve off and there are 3 hoses connected to it. When i have looked at videos of people taking hoses off tractors and wot not on youtube, there is always "some" leakage of fluid, but its not a lot. However, when i remove one of the hoses, the fluid poors out, like too much. It feels like its going to drain the tank. The machine is not running, so its not under pressure. However, there must be something im doing wrong. I am thinking that maybe the front forks might need to be down on the floor. I did it with them in the up position.
Or is there any other way your supposed to relieve pressure on the system so i can take the hoses off without loosing the entire tank of oil.
Sorry, i feel this is a simple thing, but im not very familiar with hydraulic vehicles.
Many thanks
James
G
Guernsey Submarine
Hi Bob,
Yes, ive got the manual which is very detailed. But i cant see anywhere where i can relieve pressure so i can take a hose off.
Machine is NOT running, i do know that much!
Thanks
James
Is the hose you are removing below the level of the tank?
Management
Put everything down on the ground, turn machine off ,
turn the key one click(probably not required unless there is some electro solenoids in the system),
wiggle all the levers to let any pressure out.
Key off
Crack the hydraulic tank lid / filler to let any additional pressure off & then screw it back up tight
May stop you getting a mouth full of fluid at least if you ever take any other hoses off!
Or as the monkey said, it could just be a return pipe while will just empty the tank out!In that case You’ll need to get a blank for the hose and a bucket 😆
G
Guernsey Submarine
Ok thanks. I will do as you say. everything down on the ground.
It does have electric solenoids so ill probably have to do the lever wiggle.
Yes, the handbrake valve is lower than the main tank. :(
I will also get the blank......and bucket.
I'll give it a try this weekend.
Just out of interest. If air gets into the system, is it self bleeding?
By the way if anyone is interested in the submarine projects, I do a youtube channel. Its mostly engineering stuff related to my new submarine. But there are some videos of diving my existing boat.
Hope im allowed to put that link on. :)
Many thanks
James
Many thanks
James
That’s really kool!
Many thanks
James
been in need of some new content to watch ... this is going to be very interesting .. assume the lathe's a Triumph 2000, with a 25 rpm min speed .. looks bigger in the vid.
bobthebuilder
Hi Bob,
Thanks
James
on the front between front wheels there is a lever to release the pressure in the system
G
Guernsey Submarine
Hi
Thanks for the interest.
Yes, its a Triumph 2000 long bed.
G
Guernsey Submarine
Hi All,
I went to my local plant shop and they gave me some blanks to block off the pipes. Also gave me the same advice as DaveDCB did here, which is good. I'm going to tackle it Sunday. I might even make a video!
Will let you know.
Regards
James
G
Guernsey Submarine
Hi All
Right, i did manage to have a bit better success this weekend, but still didnt get the job done. I wiggled the handle and made sure the tank was sealed properly before opening the pipes. This time they leaked, but not a huge amount, a more managable dribble.
But i still need to blank them off. There are 3 pipes on the valve that I need to remove\blank off.
The bigger of the 3 fitted this M16
G
Guernsey Submarine
Sorry, i must have sent that by mistake.
I just went and measured.
The bigger of the 3 fitted this M18 which my blank did fit.
But the smaller blank i have doesnt fit. So i couldnt finish the job.
The smaller blank i have is M16 which is a bit too big.
Any ideas what this thread may be? M15? M14?
