tools, earth movement of my area
komatsu backhoe
fiat hitachi fl 175
cams cruscher utm cams
operativo a monasterace valle dello stilaro frantumazione inerti valle stilaro reggio calabria italia
bulldozer fiat
monasterace marina calabria beach from Monday we will be ready to welcome tourists happy holidays
FIAT HITACHI FH 200 ET
old 941 caterpillar BOVA MARINA
LUNGOMARE BOVA marina dopo tempesta e mareggiata
CANTIERE BOVA MARINA Reggio Calabria dopo tempesta e mareggiata:eek:o_O
old benati 19 SB turbo loader seaside monasterace marina
old 941b caterpillar seaside monasterace calabria italia
old benati 19 sb turbo loader monasterace calabria
In Calabria, near Monasterace Marina, children build sand castles with mechanical shovels... we are one step ahead of technology...;)(y):coffee::whistle::)
fiat hitachi FH 330.3
excavator caterpillar lifting boat
Tonnara shipyard in Palmi Calabria, note the hauling trolley recovered from a trailer for exceptional transport of railway wagons and freight wagons, the excavators have been equipped with scales for hauling and lifting boats in shipyards in the area which carry out storage and maintenance of the stored boats
vecchia gru MARCHETTI Piacenza ton 25
camion astraView attachment 58694View attachment 58695
rare to see a 'ram's horn' hook block on something that small .... would need to double up on all your tackle ..... that's a BIG hook for a 25 .. ram's horn normally associated with BIG lift tackle ..... the boom has a Demag look about it ... in good condition for what must be an early '70s machine
si è una macchina tagliandata e restaurata usata per alaggio barche in un piccolo cantiere navale che fa rimessaggio il telaio del camion penso che sia astra il motore forse una fiat
stanno iniziando i lavori stagionali per costruire gli stabilimenti balneari provvisori, la spiaggia è stata livellata, ora si comincia a montare e sistemare la piattaforma delle strutture provvisorie, speriamo bene
Bergtechnik​
Schmidag​
BERGTECHNIK
Bergtechnik BC 30, modello anno '58
Bewegte Geschichte: Die kleine B 30 von Bergtechnik wurde zunächst in Lünen sowie unter der Marke Saarbergtechnik auch in Saarwellingen in der Nähe von Saarlouis gebaut. Daher war die Kleinraupe auch in Frankreich des Öfteren anzutreffen. Bis 1972 wurden zahlreiche verschiedene Typen entwickelt. Darunter auch große Laderaupen mit Heckmotor und Radlader. Danach übernahmen die EWK in Kaiserslautern die Baurechte.
Saarbergtechnik (tecnologia mineraria) BL40
