Few bits for sale
Adam
Adam
Hi,
We have parts we have lying about for sale that might be of interest people on here:
Set of New Bridgestone tracks for a JCB 8025ZTS 300mm x 109mm pitch 38 links £640 +vat
Used JS130 Hitch. 65mm pins. Good working order £700 +vat
Snow plough on skidsteer backplate £2200 (New old stock) Sprung loaded, Hydraulic offset left / right. Get ready for the snow!!
JCB 8040 / 8045 Hill Tefra Quick hitch (just the hitch as shown) 40mm pins 160mm dipper width. Will pick up pins 38mm - 50mm. New old stock. £500 +vat (comes with a Geith control box and valve / few fitting and hoses)
Delivery avalible on all items.
We also have a range of unused engines in stock. JCB 444 /448, Perkins 404d-22, Caterplilar C6.6, Cummins, Isuzu, Kubota, Kohler along with a few JCB transmissions available @ www.plantparts4u.co.uk
Hi, We have parts we have lying about for sale that might be of interest people on here:
JCB 8050 Hill Tefra Quick hitch (just the hitch as shown) 40mm pins 160mm dipper width. Will pick up pins 38mm - 50mm. New old stock. £500 +vat (comes with a Geith control box and valve / few fitting and hoses)
what're the pin ctrs please Adam and ditto the ctrs it'll the pick up ........ might just treat JakieB to that ;)
Adam
Adam
up top 343mm. I'll have to check the pick up ctrs tomorrow. It will pick up 3cx buckets. A 3cx has same pin centers but dipper width of 175mm and 45mm pins.
Adam
Adam
Shovelhands. Mite be my fault as i'd originally listed it as for an 8050 / 40mm pins. I edited ad so now says 8040 / 8045 40mm pins.
The hitch would machine out to suit 45mm pins but would need the bosses also facing to accept the wider 3cx dipper. But its getting involved..
Not for Druid it's not ;) I reckon you've got a sale.
beat me to it Doob :giggle: ..... soon drop that on the Ajax and sort the issues out .... was the centres I was more concerned about :rolleyes:
Had been considering re-cheeking the Hill I have under the VA-r ;) ... once I've created my Druidstyle/spec. S type to replace it, as that'll pick up all sorts, from Jake/CX to all the buckets I had from Mick and everything else that'll currently go under me VA-r ... which is everything :giggle: ... will handle 320 to 410 pin centres (S50) :) x 160 mm up and similarly does up to 50 mm dia. :cool: ...... jake'd struggle a bit with the 7 footer off the 'Drema though :ROFLMAO:
Hmm .... quandry :unsure:..... was gonna spend some wonga with Robert on a cylinder :giggle:
