Basically a mini digger not a micro at this size thoughThink 790 wide
Guessing the 14 on the sides means it's 1.4t weight class ?? If so it fills what could be quite a useful nicheBasically a mini digger not a micro at this size though
Does that have the Compacttilt hitch fitted ? Bit difficult to see ?
ah - helical, didn't recall you buying that
Doesn’t matter, it’s double acting, no free flow return option.@Giles on the dx10 which of the aux hoses are flow for the breaker?
I had an auger on mine before but had to buy the connectors, but auger was working both ways so either the 50/50 chance of having them the right way was either correct or didn't matter
Steelwrist do one- looks mint.
Steelwrist tilt coupler, a tilt function for the smallest excavators
Steelwrist TCX tilt coupler is designed for excavators below 2 tonnes, offers the user a tilt function & an integrated quick coupler for work tools changes.steelwrist.com
Go online old 1&1/2 ton JCB or Case built like a tank should be around that Price ,Hi there.
Like many, I am looking for a mini or micro digger for around £5k, just for some general landscaping and drainage work around our property.
Most well known brands come in a bit over budget. But I have found a Mistubishi 1/2 ton micro digger (MM05).
I've also noticed a number of almost new JPC 1.2ton (koop diesel engine) machines within budget.
So far, I have zero experience with these machines, but keen to learn.
My gut tells me I'm better off with the older, Japanese quality machine than the newer Chinese ones.
Or are these cheap new ones worth a try?
Bearing in mind that I plan on keeping it and possibly even hire it out to the odd local that needs a wee job done.
Eurocomach are now owned by CaseLooking at the Eurocomach 14 SR (p2 this thread) & Case CX14D (p6) I am pretty sure they are the same machine or same design at least. Likewise the Case CX 12 D & Euro 12 ZT Neither seem common in UK
