Brick cutting machine
Mount Hawke's even worse ... hell of a trip :giggle:
Our kid wants a toy project do upper/resto...that Kubota would have done him nicely but I'm not ready for that trip and it's out of his price range ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚.๐Ÿ™ƒ
'nother one here Dylan ... bigger but in need of a little TLC BTLs current bid - a fiver .... got to be worth a sniff at ... adjustable height/angle too -- Giles just showed me the auction site for summat else
Iโ€™ve 2 of these red bands, saw this but the frame looks bent more trouble than worth and will make 200-300 easy
think the end frames are just set at different angle
What about this. Its 35 mile away from me.
starting load of 19 amps Dylan :oops: , 1.5hp and high speed at 2850rpm ... pretty sure the 110v is how it's wound, not an alternate voltage, or it would give two sets of current draw figures - the full load figure is only for 240v, would be way bigger for 110v loading at 1.5hp starting draw
Well started a window today and as I thought and remembered it's very tedious.
Any one know anything about these.
worth every penny if you have the power to run it Dyl. Proper recirculating coolant pump and a really nice trolley set up ... will be a lump to move about, but bet it cuts nicely .. the 440V is the biggest issue
Thatโ€™s a workshop/fixed installation machine.. bargain at ยฃ500 for what it is though! Way overkill on Cheshire brick..
Have you not considered just using a dewalt 9โ€ cordless cut off saw but on a bench(afew pallets stacked up!) soon rattle through the cuts
Iโ€™ve this belle ms521 petrol, water recirculating 14โ€ blade great tool for repeated cuts. Picked mine up from auction make 200-300 every month
A couple of these plus other styles in rb auction on Wednesday
diggerjones
diggerjones
It's the dust that's the problem, we'll for the labourer ๐Ÿคฃ
I've got a old evolution saw I was thinking of putting in a diamond blade
You can use water with the dewalt ones, agreed a propper table top is much better at mitigating the dust issue!
