Spares and repairs bomag ped roller...
...If any ones interested- will entertain low ball cheeky offers.
It does actually work and I've probably done about 30 jobs with it over the last 3 years BUT it takes an age to start, to the point of putting jump leads on it to keep it turning over, and it will do about 1/2hr faultless operation untill the engine decides it's had enough and conks out under a cloud of smoke, that's fine because half an hour with this is enough🤣, and today it through a hyd drive belt, no big deal but actually decide MD I can't be arsed with it anymore and want a new one- it's earnt it's keep.
No
I’ve been looking for a walk behind for ages . That doesn’t even look to old .
I will take it off your hands for 300 quid , if you sell my mate the TB 125
It's pretty old- 2001 I think. Hatz 1B20 engine. Like I say the rest of it appears to be fine apart from the belt today but the engine is troublesome. They're handy little rollers though, I chuck it on the trailer with the 1.8t digger which makes it a neat little combination doing the odd footpath/resurfacing job here and there.
The thing with ride ons for me is they're cheap to hire if you have a lot to do and can hire the size you need. They then need a separate trip to transport etc. the ped rollers although a bit or a work out are just convenient for bits and pieces to save hiring and and I like that if I'm doing a path somewhere awkward due to terrain I can just lift it into situ with the digger.
My next one is going to have a wheel at the back though, think that will take alot of the ache out of using them...
Surprisingly not as most are set up so you have to be a midget to let the wheel run on the ground. Some are definitely better balanced than others. The mortimers are a lot better balanced I find than others. Generally prefer them to use. The new mecalacs are horrible things
How well does a single drum roller compact compared to a decent sized wacker plate ?
Mortimer make rollers ? If they are anything like the dumpers I’d have one
That's worth knowing. There's a good dealer local to me who deals in the vibroll. Thought it looked good and like the yanmar engine on it but lack of wheel put me off but perhaps if it's well balanced it wont be a problem- a wheel could be a pain in the arse if it drags in the 803 for example?
The wheels do leave distinct lines in type one and completely ruin tarmac if you lt them run in it. Try the mortimer it is definitely what I would choose. I think they do a wheel kit to fit it but as said I find they balance well enough to worry.
better ... I've got one and one is enough .... does put planings down relatively well (y) .... 2-3 hrs at a stint is enough though
