Moderattorš¾
I'll soon delete mineHard now someone has replied to it! I never knew that. How odd. It goes down so much better with a quick sorting and the big stuff sitting at bottom.
I fully agree.
20mm clean limestoneWhat did you bed the pipe in with? Presumably that makes a difference.
but not for longSunday messing around. Trying to sort a couple of wet areas so extending a 4ā French drain another 8m. Couldnāt decide to use fabric or not on a French drain so went half and half (ran out of Teram).
Kubota swivel very handy.
Experimenting with creating a grading beam on the tilt bucket, lightweight unistrut surprisingly effective.
I've not tried mine yet since I've welded some hooks on to grab the beam, tried it with 4 in 1 on the rototilt and it was good tbf but kept falling offSunday messing around. Trying to sort a couple of wet areas so extending a 4ā French drain another 8m. Couldnāt decide to use fabric or not on a French drain so went half and half (ran out of Teram).
It was just to explore the concept . Thinking about cutting a slot into a 6ā length of scaffold tube. Not sure the E10 could bend that.but not for long![]()
weld some tabs on and bolt to bucket edgeIt was just to explore the concept . Thinking about cutting a slot into a 6ā length of scaffold tube. Not sure the E10 could bend that.
been 18 hrs continuous here so far ... total opposite of yesterdayLike the Somme! Thank goodness for those mats 2 days saved already
View attachment 57622View attachment 57623
I'd've taken it off anyway ... first tree'd 've had itSorting a track out on an nt camp site base of kinder, moved digger then swapped back to tipper to move dumper as needed tipper next day not plant trailer. Mustnāt have been under bridge with it at yard looking only beacon and din mount pole annoying though.
Then wagon couldnāt get to tip well could and has been for 20 years but busy body Dorris/Karen decided now trust taken site away from renter farm she doesnāt want wagons in the farm yard thatās nothing to do with her. Trust farm yard, she lives in little cottage out front but wagon might damage gulley in trust farm yard! Anyway this oneās a letter writer so we tipped stone mile back down lane(itās a private lane) at trust ranger house so had to sneak digger back down lane and ferry 32 ton up to the site.
No mobile signal so on the old walk is talkies which are handy, gravel grids for top end of it tomorrow stop mot washing away
And blocked drain to sort causing water
Complacency, always been fine moving it around as no real low trees on main roads due to wagons/buses etc.I'd've taken it off anyway ... first tree'd 've had it
Good job none of its on public highway! Fair loads thereComplacency, always been fine moving it around as no real low trees on main roads due to wagons/buses etc.
Itās got led flashers on roll bar as backup
Good job none of its on public highway! Fair loads there![]()
Kubota too heavy to be on road on tipper but dumper is only 2136kgGood job none of its on public highway! Fair loads there![]()
Kubota is just towable on plant trailer without bucket I think?Kubota too heavy to be on road on tipper but dumper is only 2136kg
Whatās going on there?View attachment 57660hard work this weather everything takes twice as long
Looks fairly dry compared to round these parts!View attachment 57660hard work this weather everything takes twice as long
