Welder
I am considering buying a welder but am very out of the loop. If something for work needs doing we have access to a clever fabricator and I've got metal workshops on my doorstep and multiple fabrication company's a mile away, so I've never bothered.
For a personal project on the farm I've got a couple of ratty containers that need a few patches and I fancy relearning to weld.
I was taught on my grandads MIG when i was a kid (it was bigger than me) and was reasonably proficient on stick as well. Also taught to weld lead when at college. Made a lot of useful stuff, but now haven't touched a welder in over 20 years. What's going to be best for bodging plates/brackets/patches on a shipping container? Will need to be able to run off a genny as no power on site yet. 110v/230v. I know you can get cordless but not in my budget you cant!
I'm cutting a door in the side of one so i have some material handy to use for patches. Might buy a little sealy vice folder for helping create correct profiles.
Any suggestions welcome.
R-tech.
You’ll need a decent genny tho, even for the 180a model. What genny are you using?
1RB
1RB
I’ve got one of these & it’s a lot of money but it’s the nicest welder I’ve ever used
I chucked it in the van yesterday & had it running off extension leads to weld up broken electric gate hinge box.
It’s really easy to adjust just one dial to change the thickness of steel your welding & away you go
R-tech.
Agreed there service 8s great, speak to them over the phone and they usually throw a few but in for free. I know a few people that got consumables and I got a longer set of leads (quite important for the little mma machines as the ones they come with are only 1.5m which isnt great.
No chance.
Go to warrior welders. Their little diesel genny is optimised to run a mig, and it performs very well indeed. They do good migs too by all accounts.
yep I have the 250A single phase Warrior MIG ...
bloody excellent ... and 4 roller drive
Phil Weekes is easy bloke to deal with and is just over the other side of the old bridge in Tockington (used to have a unit in Bath but now runs from his home) he builds MIGs and dedicated gennies to run them, if you need remote power
this is his Ebay shop
gone up a couple of hundred quid since I bought mine
Warrior welders do single phase welders of decent size Warrior mig
I bet it was ...... how long were your leads?
neither of the websites for these give an input current requirement :unsure::unsure:👆👆👇👇..... but I'll bet it'll be more than 13A to lay a decent run down
If you’re looking for a serious welder we’ve been buying Miller welders lately in the workshop and been impressed with them. No idea about the Single phase machines but are decent bits of kit
Interesting...I was looking at gennies a while back and came across his stuff seems well priced and decent. Good to know 👍
Parweld, Thermal Arc, Rtech, ESAB, any of their small inverters but make sure it’s genny-safe if you’re running it off a genny. You could go for a single phase Miller but you’ll be paying twice as much for the same boards as in the cheaper ones. If it’s just for occasional work there’s no point going mad, if you can weld you’ll get a decent weld with a set of leads and a car battery.
Canal Navvy
Canal Navvy
The small inverter welders all seem to be made in China so I'm in favour of cutting out the middle man and buy Chinese openly. Jasic are good enough for some of the big names in welding to use for their entry level welders and Headux I'm told are a breakaway group of engineers from the Jasic fold. The Chinese seem very open to supplying just what the customer wants.....if you want the casing punched differently and painted in your colours just fine ...... add stickers and a plug and it can be assembled in the U.K. 😁
So far I'm still very impressed with my baby Headux 🙂
I'm looking at options of running a 100m 6mm arctic extension lead, vs getting the first part of the permanent electric supply (80 metre run) to an externally mounted 3ph dist board.
