PowerTilt coupler to suit Bobcat/Doosan E19, E17, E10
If anyone is after it. Fits a 016/015/216/215 takeuchi. Semi Q/H.... It'll also pop direct mount on a Bobcat but buckets are wrong.
That's mud on; t btw not concrete.
If this is cheap enough for @Stroppymonkey, then I have a brand new BMC screw type bottom hitch to suit the Bobcats that would weld straight on with minimum fuss- a ten minute job. £200 posted. Happy to weld on if he wants your hitch but can't weld, but it would mean he'd have to arrange two lots of shipping! Or I can post it to you to do the honours, that might work better.
What are the pin centres for the top pins? You need to be careful not to ground out the tipping links.
From memory there's under 5mm difference. Which was bloody annoying.
But yes, we could potentially weld on here but time would be the factor.
Yeah but I have a welder & paint 😆
Trouble is time you do too much of it you'd likely be better with a new one. Plus I'd be dubious putting too much heat on it and risking the witchcraft escaping.
I've kept it on the shelf in case we need it but tbh the work we are on for the foreseeable doesn't warrant it's use beyond the tilt bucket. The Extending arm is going back on the 015 and I intend to get shot of the 016 sooner or later for a bigger unit. So it's a bit surplus.
I welded both top and bottom of mine. Top took more heat so I just did it in stages. Bottom was no probem.
A new one with a ratchet hitch is just over 3k if anyone is interested. Harford.
Thanks for thinking of me. Think I might be best with a dedicated tilt bucket as will want to get it off quick and easily for trenching or loading as think even tilt bucket will compromise loading height
Yeah, I cheat and have been known to put a packer in the jaw of the hitch and the takeuchi bucket fits on. I've also loads of cat buckets witch are a fraction longer centers and they fit on ok without messing
Diggerdavey
Do you have any further photos of this?
