Best way to repair this.
P
Pond digger
I’ve never had anything to do with GRP, or whatever.
Can’t help with repair advice....but how need you manage that?😱😱😱😱
someone has obviously pried out those switches with a tyre lever :oops:
used to have a mate who was a GRP wizard, repaired a crane cab for me that I bought with a damaged cab ....
I'd guess that that is a pretty simple one Chris and could be sorted with a little powder/resin mix and a bit of fine mat in layers..just need a support backing whilst doing it ... then abrade to a finish ;)
Powerfab
Powerfab
Best bet would be to contact some of the mobile car repair companies "Dentmaster" etc.
They can leave bumpers like new, I'm sure they could do the same here. And the advantage is they come to you. ;)
good call that ..... pretty much the same material as some bumpers etc ... Renault in particular used to use very similar materials to form their bumpers, but don't know about present day :unsure: ... thought they're mostly plastic :confused:
P
Pond digger
Never thought of that, I wonder what they’d charge.:unsure:
Thanks
P
Pond digger
So many things I wish I knew about. Not sure I want to learn on my own machine.:oops:
Get some Chemical Metal, made by Plastic Padding, should get it in a car accessory shop or the like? It’s grey in colour and can be sanded down. Will surely be close enough for a digger?
P
Pond digger
Worth a thought, thanks.
Regy53
Regy53
I like cake
I would probably fill it first and see how it works. If it bounces out ( often do) then go the fibreglass route suggested above
If it was my own machine where I just wanted functional fix, I'd grind the surface to give a good bond and use a body filler. Then sand flush.
You could get a close paint match from a model shop for trivial cost.
If you are tarting it up to sell, I'd look for a boat yard to find who they use for GRP repairs.
