Bargain!
I drove one of their biggest ones that had been fitted with flotation tires. It wouldnt actually fit on the lorry they had bought it for as only lifted about 6in of the floor with that lorrys fixing kit. Was a monsterous thing. Not the lift capacity you would expect. About 2t as was quite an old machine. The newer version of in lifts 3.5t
Have you got a link? I've heard references to the bigger machines before but never seen one and can't find a link. Mine only weighs 2300kg. Just a baby?
Fp 👍
I guarantee after a full day on one you'll agree that all the controls on one joystick at the end of the armrest on the new ones make life a dream.😊
I have used one of the tiny lever FLTs but .. as said lots more to go wrong - it'll live outside - and I ain't gonna be on it day in, day out ;)
3 levers is fine on a counterbalance.. you can run all 3 at once if needs be. My moffet has 5 which makes you think occasionally but you soon get to grips with it. 0 electrics apart from lights/beeper and ignition circuit.
At 2300kg definitely not just a baby. Long since discontinued now but they did do a 500kg one for use on 7.5t trucks. 1 wheel drive, the mast didn't slide and rather than telescopic forks it just had really long ones. And then with such small front wheels it could drive under the underrun of the lorry.
Here is the link for them. Go down to specifications and you can scroll sideways to the bigger models. The second one comes in at nearly 6 tonnes
Odd that my 2.3ton will lift 2ton but the 5.9ton will only lift 3.5t. What am I missing?
Safe load indicator. Usually green amber and red lights on the dash.
I'm glad my grab lorry is old enough to not have any fitted on the crane. When your stood on birds nest you can feel what it's doing. Would I put a driver on the crane without....I'd say no unless I has as much trust in person as I did myself on it.
Earlier this year I lifted my e10 onto a banking, aprox 600mm above the lorry bed, tight against the wall (sub 1200mm out reach) asked my mate to lift it down. Bigger lorry lot better crane than mine. Would it lift it....Would it f**k...sensors cut it out.
Sensors for cut out are great for the numpties, great for the insurance companies...I get that but they are so dumbed down just to cater for the general plonker and poor attitude blaming it on cranes fault they didn't know, rather than apply sensibility to what they are doing
They do as much harm as good. I can't be the only person who has had the controls cut out stopping you from correcting yourself and making the situation far worse than it needs to be. Also on hiabs it doesn't disable the slew. In my brief experience of them you could slew yourself into far more problems than you could just buy lifting. Especially if you have something on inappropriately long chains.
None of that nonsense. When the back wheel won't grip I know it's heavy. When it's off the ground I know it's definitely too heavy. When all 3 wheels off the ground I'm pushing my luck... :)
