Bargain!
I missed one of these a few years back, all original paint. £500
From memory though it was a tricycle, not a full width rear axle.
been eyeballing a few FLTs myself lately .. be handy to have one about ....
candidates so far are a nice-ish S40 Hyster, 4 tonner and a 3t Daewoo with a cloth cab ...
Hyster is a bit too far away - like 500 quidsworth of tranny away ...
t'other is a lot closer but still circa 250 quid to move ....
Hyster's diesel, pneumatics and up and running, Daewoo's LPG, solids and needing attention, but half the price of said Hyster and significantly tidier. ....
But I know what the Hyster is capable of .. (y)
t'other is an unknown quantity on the capability front :unsure:
everything else about ATM is 2.5t down ...
an S50 or a H100C would be ideal ...
one of them and a 'Drema'd be capable of moving loaded boxes :giggle:
View attachment 54413 View attachment 54414
I have a 1999 Jungeheinrich 2.5t LPG with about 8000 hours on it and a 2003 Moffett with 800 hours on it. Cant rate them both high enough. Moffett is so light and good off road with 3 wheel difflock and extending forks so you reach most things. Will turn inside its own footprint and lift its own weight. Will unload a lorry of blocks from one side using the feet and Kooi forks. I would love one with side steer as well but quite rare.
The sidesteer ones I've used lost the sliding mast so even with the kooi forks they couldn't unload from one side. I would however highly recommend the manitou version. The telescopic boom makes them very useful you could even fit a bucket of need be as it has a fair range of crowd
Ugh - I wouldnt want side steer in that case! My landlord has a couple of the (very old) Manitou in chicken spec. I nearly managed to get a Moffet with a boom but missed it. I think it would be better for most things as less mast in the way looking forwards, but your vision to the right is awful. They have side shift on the boom I think.
Ugh - I wouldnt want side steer in that case! My landlord has a couple of the (very old) Manitou in chicken spec. I nearly managed to get a Moffet with a boom but missed it. I think it would be better for most things as less mast in the way looking forwards, but your vision to the right is awful. They have side shift on the boom I think. View attachment 54421
I would love a manitou ‘Moffet’ with the tele boom and get brackets for my short trailer but make big money (in my eyes anyway) then get a steering axle for it too (the trailer that is🤔) would make my deliveries so much easier
Try and get a Linde with the old bombproof Deutz.
Their Servos are night and day better to operate compared to sticks ...
yet more to go wrong LL :rolleyes:..
I like direct sticks ...
spent 30 odd years using 'em and could put a fork on an egg (without breaking it:giggle:) ...
used to have one set of forks 'sharpened' up for splitting sheet packs ...
can split a sheet of 1.6mm/2mm/3mm/etc., off the top of a pack with sticks ;)(y)
Yeah the whole boom slides on the pivot pin. They are definitely a good machine. I never found the manitou difficult for vision as the seat on the manitou sticks out the back. The one I used to use was a smaller one and would be an ideal yard machine as it was a flat floor cab only a step of the ground. If it was in the yard I always choose it over the proper counterbalance trucks as it was so easy to get on and off by comparison. And definitely better than some of the big moffets with a staircase to the cab.
Never tried or seen a big moffett? Mine is no worse than the 2.5 counterbalance to enter. Used to have a stupid flappy safety cage door thing but once it vanished then LOLER guy didn't care and life got easier. Once you get hang of the forward reverse/clockwise/anticlockwise thingy and the versatility of sliding boom amd Kooi forks then if you're out in the open then I'd choose the moffett over the counterbalance every time.
This one interesting
Fp 👍
I guarantee after a full day on one you'll agree that all the controls on one joystick at the end of the armrest on the new ones make life a dream.😊
I drove one of their biggest ones that had been fitted with flotation tires. It wouldnt actually fit on the lorry they had bought it for as only lifted about 6in of the floor with that lorrys fixing kit. Was a monsterous thing. Not the lift capacity you would expect. About 2t as was quite an old machine. The newer version of in lifts 3.5t
