you need to get one of the heated seat covers for yer lil' loader (y)
@Grahams swears by his :giggle::giggle:
I've a couple of these, perfect on cold days.
It's got a heated seat but not sure if its working need to check it
Oh to have a cab this morning early start
View attachment 54086View attachment 54087
You need one of these - only 2.5 tonnes so towable. £36k apparently, I think it looks a fair lump of a thing for the money!
Are they waterproof
No but I've used them while it's been a little damp, I've also got water proof seat covers on my micros (stops the vinyl seats from cracking and the inevitable wet arse from the foam soaking up water) so they can slip under if I wanted too
The aren't half the machine and Avant or Multione is though. Very different design.
You can get cabs on pretty much all the small compact loaders.
I know very little about any of them (other than having used an Avant on a couple of jobs and being very impressed with how it made no mess at all). Where is the JCB lacking in comparison?
Lift capacity sadly. As much as I don't really like the Avant/ Multione's (yes that's despite spending weeks a year on one and having owned one in the past too), the 403 just cant get near it for lift capacity or hydraulic flow. But they are also a lot cheaper to buy, so depends what you want to do really.
Lift capacity for the machine weight isn't as good and the oscillating centre joint is just dangerous anywhere other than a farmyard. It'll end up on it's side very quickly if you treat it like you would an Avant.
@Gunners - What don't you like about an Avant?? I'd have thought they'd be right up your street. Nimble, efficient, towable and don't make a mess unless the conditions are atrocious.
Have you tried an 860?
Having seen a few on dairy farms I think JCB have got the right product for there audience. As good as the multione/Avant are I don't think they would be stock farmer proof.
Settle down gents, here's my rant on Avants.
I've driven 500's, 600's, 700's and yes the mighty 860. To be fair, the 600 series is very capable for its size, probably the best compromise of size vs weight. The 860 in particular, whilst very powerful, is too big for the concept in my opinion. Visibility is impossible to the headstock when its lowered and you're trying to hook up an attachment, and visibility to the forks isn't great when they are below the level of the dashboard like in these pics. I'd hate to have one with a cab because I spend so much time hanging my head out the side to see what the F*** I'm doing.
The build quality isn't great with paint flaking off and plastic panels that snap if you lean against the machine too hard. Also plagued with electric issues, every one I've had on hire has either had water behind the screen on the dashboard, the gogo pedals playing up thinking you're pressing them both, or some other random intermittent fault. The 760's love to snap/ twist on the boom when you push them to lift something at their limit - a well documented issue - its happened to me too! I also hate the boom in and out is on a button on the joystick so is like stabbing with the tele. Why cant it have a roller like every other machine. You can use the little lever on the dash but that means taking your hand off the joystick which isn't very useful when you also need to boom down when you tele out GENTLY!!!
But by far the worst thing I don't like with them is you have to be 100% straight when you line up for a lift. In tight spaces this isn't always possible and if you try to steer the front end acts like a swinging hammer of destruction using the load you're carrying as the trebuchet.
Awful machine, good luck to whoever runs one of them day to day, they aren't for me.
Oh and the dealer backup is crap, as said by another user on here!
To be fair to Doobin, I think he made the right choice with the Multione, from what I can see, they look better made, although have never driven one and will still suffer from some of the inherent issues I don't like with the design of these mini loaders, but its the one I would buy if you forced me to own one again.
That's an idea for the E10!
@Gunners ref the last picture - you absolute animal!! 😂😂
I’ve only driven an avant at diggerland, considering it only had a barrel grab on it its whole life, it was literally a floppy sausage! Horrible thing to drive, and seemed very very long for such a small thing. Obviously have their place but not on my type of jobs, which are probably all lending themselves to larger machines these days(I just begrudge hiring kit in when I can just use what I’ve got)
