Tilty thingy
I was having a go on this the other day but wasn’t keen on the kubota side of things.
There is no flow sharing between tracking & being able to do anything else, it’s ec02 s30 180 on a kx030 but I can’t drive it because the rollers are the wrong way for me & to change them on dc2 you need an android phone to connect to it to do it & every person I know including me has iPhones.
It’s only got 50 hours on it but it’s not set up right, the bloke that owns it had a go in my machine & can’t believe the difference it drives.
He’s had a priority valve that is for running a flail put in (£1500) to see if that sorts the flow sharing but now the tilty has all the flow & arm & tracks doesn’t have any 🤦🏻‍♂️
This is a Kubota thing ...think @CPS says the same from his installs, its not as if the wacker has enough flow to do everything at once but it shares it out sensibly, on 8t kub if asked for a bit of oil to creep along with tracks it would stop the boom up with a bang.
Management
If the rollers are wrong just flick them out and spin them around. Or if they are literally on the wrong hand you should be able to unplug them on the control unit and swap them around from left / right joystick might upset the owner when he comes back to use it 😂
1RB
1RB
The end of the worm drive appears to stick out past a lot, Is this actually the case?
Also lifting hook looks set well back also?
It doesn’t have an oil bath it’s grease. I grease the rotate bits weekly & the tilt bits daily.
The rotation motor does stick out but is really well protected
Once you’ve curled the bucket right round the lifting hook is perfect for lifting, if I’m lifting anything heavy I just take the tilty off in a minute
1RB
1RB
My
My rotate is on the right & tilt on the left.
In my machine I’ve got Little screen to change speeds, layouts & fault codes
@Pedrod355 I think Steelwrist only do S30 on the new X02 unit. Its very similar to the Engcon EC02 you and I run, but slightly lighter (couple of kg's) according to the plate. I've never looked into Steelwrist because they never did a small enough tilty in my opinion to suit a 2.8t machine, but will be giving them a good look over the next time I'm in the market. I quite like the cast body although it does seem a little bulkier as noted by others, the rotation motor does stick out a bit at the back - not so bad on the X02 I didn't think.
I've got some footage of the X02 on display at Plantworks this year in my video about the show - not much info about them online.
And as far as Engcon backup goes, I've had a few issues with my first unit (this 2nd one seems to be behaving itself ok so far) and apart from Andrew at Engcon UK, who has always been helpful, if a little forgetful sometimes - its @Nasco Neil who's the champion guy for backup. There's not much he cant fix in person or over the phone, and it was the main sway for me to go back to Engcon for my last unit, despite Rototilt coming in with a fantastic price (with Aiden's top hitch which I have no issues using). Neil was brilliant with my first unit and it got him the sale of my next one. As everyone says, its the backup that sells the 2nd machine and for us owner operators - thats much more important than the colour of the jacket they do or don't give out!
Pedrod355
Pedrod355
As usual bang on with ur comments @Gunners. Yes Andrew at engcon has been helpful especially Tim with over the phone support. There only down side up untill to recently was having no engineers up in the Highlands.
Will have a look at your video as yes there is very little info on the X02. 👍
JerryRtilt
JerryRtilt
Knowing Neil @Nasco and being in his area is probably the only reason i would change from Rototilt to Engcon, not that i have any reason to and I've no reason to complain about the backup i've had from Rototilt although i was disappointed initially as a mayor reason i went with them was a local plant engineer i knew was about to join them and then didn't and at that time Rototilt seemed to be relying on one guy tearing from one end of the country to another. They do have far more people around the country now, its just a matter of how knowledgeable and committed they are, which i guess can only come with time and can't be easy to find the right people, but doesn't help when you have a expensive bit of kit not earning you money.
Management
Mine is a Engcon/SVAB setup, no Bluetooth phone bullshite just initial set it up with engineer and go, never felt the need to adjust any of the speed settings in the last 7 years, also other than having to paint all the black bits and tighten afew hoses/fittings it’s been trouble free! Top hitch does occasionally seize up but that’s more lack of use, a whack with a hammer while it’s being opened sorts it out along with a squirt of ACF50 👍🏼
1RB
1RB
Got some pictures of top hitch pipe work
I’ve got time for greasing it but not polishing it so it looks a bit dirty
Pretty much how we do ours to.
This machine came in for a height restrictor, this is how the hoses where.... i couldn't look at them like that.
This is how it left
I think the customer was impressed with that little bit extra 😄
Pedrod355
Pedrod355
Ok so steelwrist won’t supply there X02 unit on 2.5/2.8T machine’s and won’t do a S30 on there x04 so that completely rules them out!
Steelwrist saying S30 is for only 2T and under machines.
Wish i went S40 from the start now as options on S30 are getting limited. 😥
