Livermore Migatronic mig welder
Pretty sure the wire feed motor has packed up, can I check somehow?
If not any idea where I can get 1, suppliers number is on the front unsure if they are still trading be great to get it back up and running again
If not any idea where I can get 1, suppliers number is on the front unsure if they are still trading be great to get it back up and running againView attachment 51234View attachment 51235View attachment 51236View attachment 51237View attachment 51238
Livermore Welding Supplies were trading in 2010 when i retired and had been for decades ... colchester ave. cardiff 02920495217 is he last number I have for them -- also in Weston - Super - Mare ..... dealt wit them for years - fella called John Aspley ... 'til they took the piss on some prices and that was the end of the relationship ... John lived in Aber .. if he's still with us
Migatronic - you should find a motor for that on ebay I'd have thought ... very recognised brand
or just about any where repairing welding kit ought to be able to source one ... try Phil Weekes
Phil Weeks Warrior Welders
Phil Weeks
Unit 1 Lapdown Workshops,
Lower Lapdown Farm, Lapdown Lane
Badminton, Tormarton
Gloucestershire
GL9 1JE
will have a look for his number - got it ... 07770 867952
Phil Weeks
Gloucestershire
GL9 1JE
I'll give them a try in the week
I`ve got a Migatronic like yours, also had a wire feed fault.
Have you tried powering the motor direct (not via the welder)? Check on the label it could be DCv.
Migatronic`s of that age/range have a know problem with the PCB, which often affects the wire feed. My motor checked out OK, so guessed it was the PCB at fault I sent it to Technical Arc in York, off the back of a recommendation. They repaired it and posted it back around £70 I think.
Phil Weekes also does repairs ... give him a call too ... smaller outfit than Livermores .. smaller overheads ;)
