Grease?
Russell
Is there one particular grease I should use for the joints on my bobcat? The manual recommends bobcat grease but I can't find it on the web or locally. I can get some ep2 locally but can't remember the make. Is grease much of a muchness or do I need good stuff?
I plan to grease the digger after every day of work.
Something colourfull so you don't get iron your clothes
I use red as the supplier said it was generally better quality!! But I am easily led!!
HP2 used here but have used Molybdenum Disylphate and rate if very highly, comes at a cost though. Also it has a tendency to separate , as in if you put a dollop in a cup for two weeks you’ll notice the oil separating from the moly. If it’s sealed in nd can’t escape then it mixes back in but in most pin and bush arrangements it could be an issue. Of course a regular top up helps :)
Ive been using jcb blue grease. Seems good but my stuff gets greased every day and it was on offer a local jcb dealer.
Russell
Ok thanks. I've got some ep2 from the local auto factors, £2.20 each if I get 6. Looking forward to using cartridges as loading from a bucket seams a messy faf. I've also got a G coupler for the gun but one particular nipple still leaks like crazy. I will ask if they can send one out.
Most ag or construction dealers will supply an assortment box of grease nipples it may be worth getting a box as they do wear out and you can snap them and sometimes it's easier to fit a different angle one than the machine came out the factory
Using some weird Castrol grease that the dealer said was the recommended, not convinced and going to change to something else
diggerjones
diggerjones
Bobcat is American isn't it and they are imperial aren't they.
