Jimbo69
Does anyone know offhand the measurement for the pin centres on the E10?
Bugger, thats the third different size I've came across tonight130mm i think
Thats great thanksActually
30mm pin
105 dipper width
123mm center
big dimensions for a little one tonner?Actually
30mm pin
105 dipper width
123mm center
Yea i had 130mm in my head.......then i doubted myself and thought i better check for sureBugger, thats the third different size I've came across tonight![]()
Same as the 2 tonnerbig dimensions for a little one tonner?
Handy for sharing buckets/attachments.Same as the 2 tonner
Exactly that. The 10 and 19 share each others buckets, makes life very simple.Handy for sharing buckets/attachments.
The digger sets the pin specs, the hitch manufacturers match them. They have to be right for the tipping link setup if not using a quick hitch, if using a quick hitch then the standard is to duplicate the manufacturer’s pin centres underneath.Depends on which hitch supplied surely? Mine is Rhinox 30mm pins x 105 wide x 123 centres IIRC
