Tilty thingy
Thanks.
I have a flail with hammers that I know the tilty with have to come off for hoping I don't have to take it off much for other tasks.
If I don't end up liking the engcon I'm sure I can sell it and make a little $$
Ive had mine off once for a big tree stump - needed a ripper then probably wouldn't have bothered.
Tak should handle the ec206 well enough (@Monkeybusiness has the same setup) so you shouldn't need it off much, the wacker handles it easily with no nodding at full reach over the tracks, grader full of hardcore in face shovel mode, its a long pretty way out like that,plus it has the 45kg of gripper on it.
Edit : maybe im like a stuck record with stability but ive had 7 years of a noddy 8t Kubota and its night and day and im enjoying machine driving again , stability really is everything and to get away with the things you try do with a tilty needs a stable platform.
JerryRtilt
JerryRtilt
I was unstable, then got a bit of tailswing(y)
I only take mine off for the flail (as I can’t get enough flow through the Rototilt - it’s so easy to take it all off and not have dangling hoses as need to steal the hammer lines anyway) and the shear (as I tend to use that upto/beyond what the shear can easily cut and the Tak can comfortably handle anyway wherever possible - it can be quite a rough job from a ‘mechanical sympathy’ perspective when on bigger harder timber).
I’ve also got a Rototilt on the little Bobcat and that comes off a bit more often - I could go down a tilty size on that machine and direct mount and I doubt I’d ever take it off then.
However, for my use a top hitch is a must really. But I hardly ever dig holes….
I’ve never heard of Easytilt but this looks a decent value-for-money package to be fair…
Incidentally, a photo popped up on my phone this morning, 7 years ago today your first one went on😲
Just ordered a scandi tilt bucket for my 8t Tak which is my secondary machine, not sure if it will make it more or less frustrating after using the 3t with tilt and rotate 🤔
Thats going to mess with your head ..
Skandi bucket means rotate in your head now !
Doesnt look like any engcon,rototilt or steelwrist but if its plug n play and cheap they might be onto a winner.. so do the machines hitch lines run the hitch on the tiltrotator or will it need some electrickitry ?
The cheapness will soon be overridden by the cost of replacement rotator motors
JerryRtilt
JerryRtilt
Couldn’t see any electrical connections, hitch could be manual?
The rams so far forward must be very exposed when the buckets crowded round.
