Is it your cock up or glazers?
Glazing Channel suppliers.. ‘12mm glass channel’ I just assumed it was for 12mm glass, ie there would be some tolerance in it, no it’s dead on the same size! Could just get a offcut of the channel to fit on it, but when the glass is 2.3meters long there needs to be abit of wriggle room, there was not 😞
Lesson learned - measure with callipers before ordering! Or on the next job let some bugger else do it 😂
I’ve got a great glass/window guy round Bramhall and Cheshire way if you ever need one. Does loads of glass balustrades etc
Did this walk on glass for house dad built for footballer in wilmslow aka the up the skirt
I don't do as many repairs as i used to now, I did have a thread on the old forum with what i used to get up to daly. Still like to get stuck in to a repair every now and then.
Like this ram re-rod for a local customer.
Fencing weekend. Father has a lorry load of concrete sleepers which we are using for gate posts and strainers and anything important. Wood rots off at ground level in 10ish years which means that tomorrow I’m replacing a 2012 gate post that’s snapped off already. I doubt I’ll outlive the concrete one. Pigs to handle though, and I definitely want a bigger digger than the E10, but it wont pay :-(
Solid....are you trimming the top :)
Around here we use alot of granite gateposts that hav been split off moorland rock. But with there tendancy to snap very easily I did wonder about digging a gatepost shaped trench filling it with concrete and rebar and then digging it back out once gone off- voila a granite looky like that won't snap😁
Sprinkle a bit of grano dust on them similar to the conservation kerbs and it will be perfect
