Wanted trailer
Looking at getting a ‘car’ trailer to tow behind my lorry but needs to be at least 7’ wide and 10’-12’ long only got to carry a ton or so but will be doing a fair few miles
seen this🥸
are they any good
will I be blowing the little out all the time
seen this🥸
are they any good
if it's on indespension rubber units ... run away fast .... none of their products were ever great
What is the issue with these🤔
surely as long as there not over loaded should be fine👍
I ran indespension trailers for a good while with no issues at all.
I even had one that'd been jack knifed. It had a slight bend in drawbar, no issues going forwards but harder to reverse.
In terms of the rubber beam axles again I had no issues at all in that dept
That’s my thoughts🤔
Must be a fair few about 🤞
As for the brake’s behind a lorry, don’t need any🤔 it’s hardly going to get the better of 18 ton of lorry and hiab😂
I Have Had 2 Brian James trailers now with the rubber beam axles and no problems at all. I have run the length and breath of Ireland with them full loaded...... and have you seen the state of the roads around here :LOL:
I just sold this one, great trailer but they are a bit under 7 ft wide
I've had 1 for 14 years been good trailer
Canal Navvy
Canal Navvy
I'm trying to remember how long ago it was that the rubber suspension units were unreliable 🤔 . It seemed to be pretty common for them to go loose, creep outwards or the wheel and hub sheared off.
We all went back to beam axles and leaf springs though it sounds like they may be worth another look.
Trailer combinations of similar weights do cause less problems, a towing vehicle of a much greater mass can bully its trailer and cause cracks in the drawbar that would not be seen when used with a non hgv tug 😉
I think it's mostly a case that when they do go they seem to go quite spectacularly in comparison to a snapped spring on an ifor.
I had a weird box trailer on indie units..3 or 4 years old... suspension units has already failed...litterally didn't rise at all when we forked the body off...yes it weighted about a tonne and they were permanently loaded but put me off them.
Plus hate the hitch compared to ifors.
And we could talk about resale....
On the plus side they made in Horwich England not Wales 😊👍
One failed on an indispesion challenger with a digger on the back. The wheel came up and got wedged in the wheelarch doing a fair bit of damage. The other side failed as soon as the first one did. It then lifted the back of the van right up as it was a back axle meaning the lads where proper stuck.
New trailer had to be dropped out and that one hiabed away. An I for with a snapped spring would most likely finish the journey
Obviously that's why they are shite 🤪
