Bobcat bucket brush
  • Thread starter heritage machining
  • Start date
heritage machining
heritage machining
Ok so I'm currently doing a job that involves lots of sweeping roads (kerbing) and I'm getting fed up of it so I was thinking of getting a bucket brush for the bobcat so my question is are they any good what are your experiences of them I will get a second hand unit as new ones are out of my price range.
Thanks Tom
Had a sweeper brush that went on the front of the manitou. Done a job but could also throw some dust around if you didn’t know what you where doing!!
They are really good as above you may need to water the ground first before you engulf everyone in dust. Get an agricultural bucket brush attachment. Way better than a sweeper attachment. A proper bucket brush only flicks the dirt a short distance into the bucket. Some of the sweeper attachments have to pick the dirt up and carry it over the top of the brush and deposit it in the hopper.
heritage machining
heritage machining
I saw bucket brush ready to go on a bucket for 1000 quid does that seem ok only thing I'm not sure about is the weight as the 553 s swl is 430 kg
heritage machining
heritage machining
This is the one I was looking at
They aren't heavy things tbh bobcats regularly run them in combination with a patch planer.
I don't know what the are now but remember sorting a new one new with bucket for a telehandler 8 years ago for 1200 quid
Had mine out yesterday. Great tool. Swept up the edges of the trench to collect any rogue stones after backfilling and then cleaned up where a pile of chip sat for a few days. Also did the driveway around the job where we’ve been running on for the last week with everything from chip to dirt.
It’s oddly satisfying. The other half must feel this pride every time she gets the hoover out, the lucky bitch!
F
fred
It’s oddly satisfying. The other half must feel this pride every time she gets the hoover out, the lucky bitch!View attachment 51031
wimmins work that
The Cat one you can run over the top or under and in. If you run under and in you need to run the bucket on the floor so generally we just use that function at the end for picking up small heaps. Long runs over the top works far better as you can carry the bucket. Two considerations, they eat brushes pretty Quickly, and you might want to consider a kerb brush attachment.
wimmins work that
you lads wanna hope that neither of your 'significant others' look in here :oops::LOL::ROFLMAO::ROFLMAO:
I very often hoover ours and it is very satisfying watching the crud vanish :cool::love:
I never cease to be amazed at just how good our old DC01 is at clearing up .... gets a good blast out with the airline every two months or so and sucks like a demon 95% of the time ... when it doesn't it needs 150PSI to bring it back to its old self
One of Mr Dyson's best products ever IMHDO
heritage machining
heritage machining
Got that brush looks good brush not too worn got a bit of interesting piping to the motor I think stuff has been joined to extend the pipes as far as I can see the motor just has a feed and a return I will get flowfit to make some new pipes next week as they are not pretty
motor should have a cross line relief valve in the lines to cope with when the P flow is stopped or it'll try to stop dead ... and won't like it ... can improvise one with a couple of Tees and a non return valve between the tees, same as a flail motor
Left hooker
Left hooker
Metal plastic metal ...... slows the wear down plus the metal ones helps stubborn dirt lift better
I’ve got one near Manchester would take a £1k for was off my skidsteer great bits of kit.
heritage machining
heritage machining
motor should have a cross line relief valve in the lines to cope with when the P flow is stopped or it'll try to stop dead ... and won't like it ... can improvise one with a couple of Tees and a non return valve between the tees, same as a flail motorView attachment 51188
That answers my next question which was what is this thing I thought it might be a relief valve of some sort
can you put up a more general/broader field of view pic please ... looks like a CLRV .. weirdly plumbed though :unsure: .. but can't see what's on the ends of each line
