Cue the jokesView attachment 50744
Read about these guys recently. Known as yellow bellys..
No but I can't figure What's going on looks suspiciously like it's been abandoned...Was it parked up in Cuerden check point?![]()
highly unlikely that they're spark erodedThey’ll be cut with filament wire won’t they? Forget actual name but brake factory has one for cutting moulds
No I meant EDM the fine wire cutting methodhighly unlikely that they're spark eroded
Places in Sheffield can still see the saddles etc they used to sit on by the grinding wheels, all run off water wheelsView attachment 50744
basically a new name for erosion ..... Electrical Discharge Machining, just sounds fancierNo I meant EDM the fine wire cutting method
Comments on Twitter post and that article say it was EDM or spark erosion by another namebasically a new name for erosion ..... Electrical Discharge Machining, just sounds fancier![]()
yep - "wire cutting" is an EDM processbasically a new name for erosion ..... Electrical Discharge Machining, just sounds fancier![]()
bet that ad is a few years old
Surplus from which war??
nuclear reactor was my first thought .... then read the caption
nuclear reactor was my first thought .... then read the caption![]()
Steel floor with a sprinkle of concrete..Must save a lot of money on the concrete![]()
Looking at the doorbell and outside light I've seen enoughhow to get proper attention
on a local development ..... bet they're seriously popular
Meter box looks out and cill looks out of centre with sashesLooking at the doorbell and outside light I've seen enough![]()
