JCB issue
Shtiwe
Shtiwe
Hello everyone! I'm happy to be a member of PlantTalk Any Help would be great and very much appreciated 👍 we have JCB model 537 manufacturer year 2001 we have problem in transmission I need electric and Hydraulic Schematic for the machine to solve the problem .
Thanks
Check transmission oil level! ATF, are there any leaks underneath?
(I did have one of these once, brand new from the factory and the gearbox bung had fallen out! It’s 1/2” BSP so had something on the van I could bodge together to get it moving)
Shtiwe
Shtiwe
There is no leaks and I changed the oil and filter recently
how soon will it move again? My first uneducated thoughts are it’s getting too hot… i.e a cooling issue maybe?
what's your average ambient temperature there @Shtiwe ??
Toasty…..
Libya - Climate
Along the Tripolitanian coast, summer temperatures reach between 40 and 46° C (104– 115° F ); farther south, temperatures are even higher. Summers in the north of Cyrenaica range from 27 to 32° C (81–90° F ). In Tobruk (Tubruq), the average January temperature is 13° C (55° F ); July, 26° C (79° F ).
I’d say look at the cooling system, clean radiators? Thermostat working? Coolant clean/topped up? Fan operational etc.
One result is a **service repair manual** for JCB 537-135,550 telescopic handler. It contains detailed information on the transmission system, including wiring diagrams, hydraulic diagrams, fault finding, and troubleshooting.
Another result is a **service repair manual** for JCB 537-130 telescopic handler. It also covers the transmission system, with wiring diagrams, hydraulic diagrams, fault finding, and troubleshooting.
A third result is a **service manual** for JCB 530-70 telescopic handler. It has a section on the Powershift gearbox, with instructions on how to remove and install it using a special transmission jack.
@Regy53 :rolleyes:
Shtiwe
Shtiwe
I don't understand the relationship between this matter and my machine problem
How can I get the service repair manual
Can you help me.
buy one from JCB
the guys are asking about your cooling system as it is all related .... your oil cooler also needs to be clean and free flowing cooling air .. but if your ambient is in the 40,s it is even more important ... from what you say it all points to overheating in the transmission, especially when you have a tranny light on warning of low pressure ... if the oil is overheating it'll be like water
Transmission oil pressure low
Shtiwe
Shtiwe
buy one from JCB
I posted earlier There is no leaks and I changed the oil and filter recently .is the Hot climate directly affects the oil ?
Shtiwe
Shtiwe
Is there a way to download the service repair manual for free?
