Perkins 103-10
G
GeorgeTRV
Hi guys.
I have a jcb 801.4 with perkins 103-10 engine.
Recently I've replaced the piston rings and the injectors heads.
Now the engine is giving blue smoke, no oil consumption..
I think the injection timing need to be adjusted.
How can I check the timing?
The injection pump has already 2 shimings.
I know that one shim is giving one degree.
Shall I remove all of them to see it how is working?
Is someone can give me advice, we can chat on WhatsApp.
TIA
Did it smoke before rings, and have the shims always been there?
I’m thinking the gears need checking. Is the pump gear a tooth out?
G
GeorgeTRV
It wasn't smoking like that before.
The 2 shims was always there. Never touched the timing gears.
I'm thinking, if the injector head is new, removing the shims will adjust the timing to 0 degree
Show me injector head?
G
GeorgeTRV
Nozzles👍 take the injectors out put them on the ends of a pipe, turn the engine over see if you get a good atomisation(spray)
