E10/dx10 hydraulic fitting thread
As above does anyone know what thread and pitch the standard hard-line pipe ends are for the quick release fittings? I have a pair somewhere but can't find them so looks like will to pick up another set
Got some adapters sorted was jic unsure on what ones as can't read the writing but looks like mfs6-6 but can't match the part number.
Auger working fine, no change over lever just works for breaker or both way rotation on the pedal.
Its not ideal but just using it on the front jaws of the whites hitch as need to switch back and forth between bucket and auger and bit of a faff taking hitch on and off.
There was a two pin hitch for a kx015 but the 30mm pins are only 90mm centres, was surprised they are so close
I believe these are the right ones? Not used mine yet as breaker been at mtk and had no need for it yet
they were bloody cheap :oops:
surprised you couldn't find a solid M/F adapter ... must be pretty fragile with that swivel nut set up :unsure::rolleyes:
IIRC, 's what lil' jake is (8015), but 25mm pins :unsure: ... off the top of my head (which still ain't the best, ATM)
