Headstocks for Takeuchi 216/016
i have been paying £110.00 for s30-180 could be an earner for some one if it could be done for £80
:eek: :eek: as in:- two cheeks and two pins fixed between, to weld on? no base? :oops:
have said before .... I spent a lot of time making the wrong things in my workshop :oops: ..... could've turned out a few o' them in a day :rolleyes: ... Kerching ;)
some of you might like this :giggle:
and the PDF ;)
  • Symmetrical-Quick-Couplers-for-Excavators-June-2011-edition (1).pdf
Hg2702
Hg2702
6mm isn't enough for a 1.7t machine in my book.
Well, I'd bend them at least :ROFLMAO:
Had a price from the people supplying my grab and rotator for a hitch plate. £260 +VAT!!!
A pound saved is a pound earned. £260 for a morning in my workshop is pretty good earning for a rainy day!
These aren’t home made and came from approved hydraulic at £140 a piece , they have been on a flail for 2 years a grading beam and a set of forks and haven’t bent yet so there doing an ok job in my eyes 👌🏽
Funnily enough it's Approved Hydraulics who quoted me £260 for one to fit my rotator. Bloody glad I didn't take them up on it.
There's home made, and there's Doobin/Druid/Mog 'home made' which is a very diferent kettle of fish ;)
You might get away with a 6mm bottom plate on a hitch plate if it's to be bolted with plenty of bolts directly to an implement with a nice flat mounting surface and dogged tight. But such a thin bit of steel being subject to repetetive 'pull' forces from being mounted on something like a set of pallet forks or a post knocker doesn't pass my mental risk assessment. Too much potential for the thin metal to stretch between the bolts and the clevis wings, leading to stress cracks and eventual failure.
Especially as the cost saving in materials for the bottom plate (6mm vs 10mm) was about £5 at the most, and you were charged £140!!
There's home made, and there's Doobin/Druid/Mog 'home made' which is a very different kettle of fish;) ....... doesn't pass my mental risk assessment. Too much potential for the thin metal to stretch between the bolts and the clevis wings, leading to stress cracks and eventual failure.....Especially as the cost saving in materials for the bottom plate (6mm vs 10mm) was about £5 at the most, and you were charged £140!!
Absolutely Doob ..... not yer average DIY back yard builds ;):giggle:
for them 'as never seen 'em afore:-
S50, bolt on under 12t Mecalec
bolt on/weld on S50s for 12t Mec
6t 'Tachi pick up for Kinns HPX grab
direct to 15t 'Drema (400 x 270 x 70,s) and under 'Drema's VAr (400 x 170 x 50,s)
Under VA-r's Hill hitch
blade fork adapter for use on VA-r
couple more for my own Kinns and block grab
Hg2702
Hg2702
All attachments have 4 bolt holes , they’ve been on an 80kg flail a home made grading beam and as said home made pallet forks I havebt
I’m just going on the basis if they’ve supplied it with the flail so it must be suitable , regarding the pallet fork they barely got off the ground due to weight so since have been adapted to clip over the blade so no chance of anything shearing off there, the last attachment I have a plate on would be the homemade grading beam, a no frills affair but ideal for the job 👍🏽
