Track Dumper options
Pedrod355
Pedrod355
Might have job coming off requiring a track barrow/dumper,
Anyone got suggestions on brand etc etc, Never used or know anything about them…
Something like the jcb dumpster with high tip i’m thinking
Fms1
Fms1
I’ve had a few (apart from the Slane track) and the Jcb is the best (have two still), does everything I’ve needed them for
I see they are on offer at the moment for £7999+vat
Jimbo69
Jimbo69
Any one used the cormidi track barrow?
I’ve had one for 3 years and can’t really fault it.
2 lads with a barrow each is faster I've found.
Seriously?
Maybe for the one in a hundred jobs where the access is a narrow sideslope and it needs to be loaded straight up a long skinny ramp into a tipper- but there's an electric barrow for that!
My Chinese lumag carries 6 full 600mm micro buckets at a gallop if you have the room- you'll be walking very fast behind it. If you've got lads who are pushing more than a heaped 600 bucket up a hill in a wheelbarrow all day long then give them a pay rise! I wouldn't even entertain a barrow save for the smallest of jobs.
Seriously?
And finding 2 lads who can work!
I've used most track barrows around at the moment.
The diesel Slanetrack is head and shoulders above the rest in terms of capacity, power, build quality and noise levels. Things that let it down are its not the most controllable thing even with the revs down, in a tight space its easy to accidently knock the skip into the wall when trying to be gentle turning. Its also the most expensive and as expected for its capacity - quite a wide and large thing down an alleyway. So not for the tightest of jobs but otherwise one hell of a barrow.
The Cormidi's are great little barrows and I used to really rate them, but the C55 I had recently with the Loincin engine was aweful. It struggled to power it, was hard to start and the tip angle of the skip was dreadful even with bone dry shingle. God knows how much would get hooked up if you had wet clay in it.
Shame because the Cormidi used to be the one to beat in terms of size vs capacity - and they were rapid little things too.
I actually bought a JCB HTD5 in the end because value for money - you cant beat it. Diesel engine, electric start, good capacity for its width, tip height is really good and they are one of the cheaper barrows out there. Bad points are they are noisy, turning wasn't good unless you were on a board (the new ones post 2021 have better track motors so hopefully solved this problem) and they are a pain to work on if they go wrong. But I think I'd go JCB again if I was in the market for one. The Slanetrack is a great bit of kit, but no good if it doesn't fit down the side of the house you are working on, and at a third of the cost for the JCB, you can buy a great set of bluetooth ear defenders to wear whilst operating it :LOL:
Pedrod355
Pedrod355
Excellent info 👌🏻
Russell
But with a tracked dumper one bloke can drive the micro and fill two six yard skips in a day if the diggings not too hard.
I personally wasn't a fan of the JCB so would be looking for something with 13 hp and a minimum of 0.25m3 hopper.
William127
William127
Slanetrac for me, I went for the petrol. No complaints at all really performance wise. Moved thousands of tons with it, much out and materials in. Most months it pays for the finance on it being cross hired and or used, a couple of days a month, by my mate who works out of the same yard 👌 👍
It's not the smallest but I have a muck truck if needed.
Looked at the jcb before i bought it, but it didnt do much for me for the money. But if its what suits you then its certainly better than a barrow!
I've always got half an eye open for an old Hinowa, mainly because I used to use one when I should have been at school 😃 😀, and also because it would be a handy second machine sometimes.
I've not used the slanetrac apparently good but new are now something like 11k+ for the petrol there is a "pup" version which is marginally smaller and holds 750kg but is still 10k
Kubota I think is 10k ish
Unsure on the cormidi the c50 was similiar price to the htd5 but was petrol plus has a smaller skip but tracks very well my old c6.5 is absolutely rapid but dog crap at tipping and lifting, mine very rarely empties the skip.
There is a c60 version which is diesel with a 600kg payload but at the time was 3k more than the htd5
Htd5 bang for buck is probably the best buy mine has been excellent, tracking let's it down but it lifts higher than most of the others and very rare it doesn't empty the skip, only sloppy, sticky crap will stay in.
In the 6 years I've had the htd5 it's literally shifted thousands of tons over miles, it did have a valve block within a few months of ownership but other than that it's had two accelerator cables and a starter motor (due to some idiot leaving the key jammed in the start position) I did have a split pipe but that was from it being tight against the frame but was a good 4+ years before it went, my only other issue is the pullstart has come off as the bolts that hold the recoil and cover rounded them selves out of the hole. Still on original tracks
Only 2 6yd skips!
We can 2x 8 wheel grabs full in a day and that's not hard or long days.
The track barrows are way too slow.
And as for 1 person on the digger and dumper, I've been there and don't it and it's a very slow way of doing (for me)
Seriously?
Yeah totally serious.
For me track barrows are completely useless.
On the flat 2x 2ft buckets worth go in the big green barrows.
People now just seem to think get a digger, get a dumper ect ect. Wheel barrows £ for £ are the best muck moving thing out there.
I also like how everyone assumes its just lads who I've got on barrows, I'm usually one of them. 🤪
