Dust suppression bottle
Valve went in my stihl one today, 10p piece got it back working
Jimbo69
Jimbo69
Just came up on my Instagram feed…
Some guys at work recently got some of these. They are good, because you fill them direct from a tap it’s always clean water going in them so there’s no crap to block the jets.
The hose on them is a bit fragile though, ours has kinked in a couple of places. They’re also no good if you’re in the middle of nowhere without a tap.
heritage machining
heritage machining
If you don't mind a bit of diy a 20l can with a tyre valve and a hose nipple in the lid works well with either a foot pump or a tyre compressor or if you feeing cheap I have managed with the hose pushed through a tight hole in the lid and a tap to regulate the flow on the outlet best thing I have used is those blue plastic 30 liter drums with the snap top lid as they are easiest to fill
Russell
Is it just a spring/bladder type of arrangement?
