Spare and repairs Bomag 71 roller for sale
A genuine offer of £50 and a mars bar is far better than someone offering £1000 with no intention of committing 🤣
Oh has it indeed!? I'd better check hadn't I🤣
undo the plug with the two flats, that the tap is screwed into .. filter attached to the back of that .... might wanna drain the tank down first, the price fuel is :rolleyes::ROFLMAO::ROFLMAO:
if that's about a certain ride on .. the asking was a grand .. no offer was made, but a couple of mars bars and a fifty'd've created a lot more enthusiasm :p:LOL:
Had a look last night. No filter inside. Just goes straight into the fuel line. Only an online filter which is newish. I also blew the lines out. See you can buy a complete rebuild kit for the Hatz engine. Injector, piston all the seals and gaskets etc. £790 odd quid though. These rollers new are around £8k. Perhaps it's worth getting the engine rebuilt....
What actually is the starting issue?
Cranks over for ever before it actually fires. There is fuel coming Into the inline filter, but must take about 5x 20 second cranks before any life happens. Once it's started it will restart fine whilst engine is warm and the whole machine works fine for about 30 mins. After 30mins the engine bogs down and eventually will cut out with black smoke.
start issue is the fuel is running back down the lines from the injector and needs the fuel pumping back up .. try bleeding it at the injector coupling next time
bogging is either fuel filtration, or it's getting hot and starting to nip
Yeah I think thats what it is- getting too hot. Because it's always worse if working it up a slope or if it's a baking hot day- especially being air cooled I guess. What do you mean by starting to nip?
rings nipping up in the bore is the usual, 'cos it's overheating ...... mine does it occasionally if it's used for a prolonged period
So once started does it tick over for ever or still only for 30 mins?
Yeah would tick over and does it fine too. But once the vibrate is engaged that's when it takes about 30 mins for it to start causing problems- less if it's a hot day or being worked uphill etc. I try and work round it by backing up the slope in non vibrate and then vibrate going downhill, lasts longer that way.
nipping up/cooling issues for sure ..... get yerself a punkawalla for hot days :ROFLMAO::ROFLMAO:
any chance the fin-ing is blocked up with crud, on the pot/head ? take the covers off (if it has any) and give it a good blast out (y)
is your oil level bang on? not a lot in them little motors so needs to be kept right and check it level
