ISO Shipping container wheels
Grahams
Grahams
Heavy duty wheels to move shipping containers. Two fixed and two swivel. All with brakes.
Not your Chinese scaffold tower wheels welded to twist locks, but the real thing.
£1000 plus postage
You selling up mate :eek::ROFLMAO:
Grahams
Grahams
i rekon i could use these... i need to move my loading ramp about somehow... just so expensive :D
It’s all relative. The scaffold tower ones on eBay are £1790 a set.
Fraid they wouldn't stick the pace under mine :( ... must be going a good ten tonne each :oops: ..... they were all that sort of figure when they arrived ... some of it's just gotten moved around :) ...... and'd need some bloody good plates to get rolled around on :unsure: .... IMHDO the easiest M.O. is gonna be give Russel 350 quid to come back and shift 'em again for me :cool: .... that or get Alex and his Mec or @fred an' his Drema to pop along one day and we could have an end each and walk 'em to their new homes :rolleyes: ;)(y)
thought it had wheels already Ross .... otherwise get a pair of flip ups ...... anyway ... you got two FLTs now ... end/side each - job done (y)
Regy53
Regy53
I like cake
Nope was going to weld a couple of jocky wheels on it, however never did. Shes a heavy lump and the weight disto is a big deal when you tilt / dump. to be fair i lifted her in a perfect position in the new yard two months ago and not looked back, That said if i needed to apart from some tracked machines i might struggle. the welding idea was to be able to at least push / pull her about on at least a free wheel
Regy53
Regy53
I like cake
Earlier today
instead of jockey wheels ..... how about a couple of rams with castor wheel set ups on them ... then just pump them down to lift the one end ... they'll swivel in the rams and only need single actors and a hand lever pump, tee-ed between them, to operate them ... be an easy solution :rolleyes: need to be some sort of jockey wheel to cope with them :oops:
didn't they have landing legs on 'em :unsure::unsure: or is that for getting the loading height right:rolleyes:
