Kubota with Tiltrotator
Well the Kubota KX57 turned into a Wacker Neuson ET65 (pronounced "noyson not newson" apparantly 🤷)
Was either the wacker, tak tb260 or new 60-5 Kubota, the new kubota looks good to me but by the time a tilty goes on it its beyond my budget so after having a quick demo on a ET65 set about finding one ....fancied a tab boom but this standard boom cropped up and was v tidy and figured it would be flexible enough by the time it gets a tilty on.
Late 2017 ...no dpf or ad blue so that's got to be good.
Only had a couple of days on it so far but fairly impressed overall.
Lots of nice touches and seems really well thought out - they have definitely put some effort into the details.
Few bits to mention are 3 pin bucket linkage setup that gives a larger range of motion - that felt like it made a difference ditching tight up looking through the door today - front window mechanism that can also take up lower glass and leave it all open even has a position that leaves some glass stuck out to help keep rain off - as good storage spaces and layout in cab- good lighting all round in the skirts etc - decent size toolbox - all pins greased from one side etc
To drive its pretty quiet - good on juice after the Kubotas - smooth and fast with plenty of power, it picks up the 8t Kubota buckets with a Strickland s lock which does 45mm to 60mm pins and handles them fine,although it's on a really compact undercarriage which suits me but it's pretty low and might not be for everyone, big buckets,long arm and small undercarriage isn't a great recipe but it does pretty well not to be too noddy tbf.
Certainly more to like on it than dislike.
Photos of reach compared to 3t and 8t Kubotas
View attachment 45110View attachment 45111View attachment 45112View attachment 45113View attachment 45114View attachment 45117
interesting tip link that Kev
Geometry is v good on it 👍
only down side of that is the mechanical disadvantage of the tip ram's effort being 'geared up', instead of directly acting on the link's geometry :( ... does improve though as it comes around into line with the cylinder rod and can see why they've done it .. must've taken some fine tuning in the design stage :rolleyes:
No such thing as a free lunch ....pretty good photo to compare the 2 links
It looks a bit gangly but it also looks like the ram can deliver better from that position
Does Engcon offer a detachable and an integrated grab for ec206 ?
Not done much searching but I've been quoted for a grd40 detachable grab but the gr05 (10?) Seems to be integrated?
I suppose with the new detachable gripper you could always add it later if it seems to swing it about no bother.
Top hitch - no top hitch - gripper no gripper ....spending 20k or so focuses the mind to get it right.
Someone asked me this question the other day.
My simple 3 ton has a direct mount and has never been taken off.
The 8 Tonne machine has the top hitch. The unit has been taken off once in 2 years for a muck shift. Next muck shift if stayed on!! I have the option of the gripper but for my work I have never felt the need. But I do have a grab bucket on EC-Oil that does get used occasionally for gripping fence posts and pulling them out!!
Management
Top hitch if you use a breaker, if not direct mount it! I only take mine off for breaker work nothing else!
Didn’t bother with gripper as it’s extra weight and ££, they get in the way and it doesn’t hurt to focus the mind occasionally to pick stuff up with the bucket - old skool trickster way!
Asked on Facebook specifically about the et65 and top hitch and a fair few lads answered and there seems to be about 50/50 split in opinion so I guess it comes down to the work you do.
Quite fancy the detachable gripper....its 4k worth though so would need to spend more time on it than on the floor.
£4K!!!! Get a decent grab, you’ll want one anyway once you have a tilty as the gripper can’t do what a grab can.
