electric die grinders
Russell
What are they like for removing paint/rust scale with a small wire brush? Im planning on using a 4 inch angle grinder with a selection of poly wheels, sanding pads and wire brushes for the larger areas but want something that gets in the awkward corners. I have tried using a brush in a battery drill but it doesn't do a lot.
I have a battery one and tbh it’s way to fast for wire brushing I think, unless you can get one with variable speed? I’ve used it in a pinch, but it’s not ideal.
Just bought a PCL air one, much lighter and easier to use. If you’ve got air, that is.
I use a straight grinder with variable speed, if you have it sped down enough it works ok with spindle mounted wire brush, it's a roughly 30mm diameter twist knot straight out wire brush I use and if you have it too fast the wires open right up like a flat wheel type 🫣.
No idea how it works on paint but does the job on rusty old steam valves 🤠
Die grinders work best with flap wheels, cylinder wheels, and with good tungsten grinders they’re unbeatable for grinding crap welds out of corners. With wire wheels you need to have a light touch or you‘ll end up with unintended piercings.
no where near as much guts as a leccy though Bri .. got two of each -- air is great for a tight spot .. leccy certainly takes it out
I’ve the DEWALT battery die grinder
Had to clear some lime render off some stone work started with drill and wire brushed slow painful going, tried it in 20,000 rpm die grinder oh wow what a difference obliterated the render off the stone but left the stone fresh still.
Destroyed the cheap wire brush and was finding wires for days afterwards lodge in jumper etc,
Have since bought some 20k rpm rated brushes much better in the die grinder 👌
Perhaps not Gra, but I’ve tungstened some big welds out without stalling a PCL. I can see where an electric one would be better on Giles’s work, though.
yeh you have really got to be going for it with a carbide burr to stall a little air grinder (y)
