Yes, command control, two pods with a switch on the RH pod to change from Backhoe to ISO and jack legs on the LH pod.Servos
Yup that’s it.Yes, command control, two pods with a switch on the RH pod to change from Backhoe to ISO and jack legs on the LH pod.
@doobin The jaws on my 4in1 seem slow opening & closing (compared with youtube videos) & it stalls easily if driving whilst the hydraulics are still activated. Is this normal or could the flow be restricted somehow? Its an attachment that we are definitely not getting the most out of but can see the potential of it in the right hands.Very. I’m expert level with the multione and 4 in 1.
I’m aware that’s an option, it just seems that the front half of the bucket is very short.
What model? Make sure high flow is off, it doesn't like trying to stuff all that extra flow into the small pipes on a 4 in 1.@doobin The jaws on my 4in1 seem slow opening & closing (compared with youtube videos) & it stalls easily if driving whilst the hydraulics are still activated. Is this normal or could the flow be restricted somehow? Its an attachment that we are definitely not getting the most out of but can see the potential of it in the right hands.
8.4SK. Thank you, I'll check regarding the high flow but think it has been.What model? Make sure high flow is off, it doesn't like trying to stuff all that extra flow into the small pipes on a 4 in 1.
Same as mine. Double check the high flow, most likely the problem.8.4SK. Thank you, I'll check regarding the high flow but think it has been.
Thanks for your time @doobin .Same as mine. Double check the high flow, most likely the problem.
@doobin I think you were probably correct. I have also managed to increase the speed of the bucket opening by opening the valves slightly with instruction from Jordan at Compact Loaders.Same as mine. Double check the high flow, most likely the problem.
Just shimmed the legs- down to the last shim so will order more pads. You were so right- what a world of difference!!Yes, I had edited it but you beat me by replying quicker. Lol.
Legs not shimmed right makes the world of difference, wear in other parts can be easily lived with. Look at it this way, you need a stable base to start with.
Waxoil on the leg wearing surfacesFirst job! Then called in for a new tyre.
Should I grease the jacklegs? View attachment 45377View attachment 45378
Will do.Waxoil on the leg wearing surfaces
Waxoil is specified in the JCB manual.Waxoil on the leg wearing surfaces
Jcb have there on version of waxoyl now. I think it's called boomtec iirc.Waxoil is specified in the JCB manual.
My trouble is it's not available in Oz.
I use something called Lanox that seems a similar product.
MX4G LANOX Lanolin Grease
LANOX MX4G Grease is a non-toxic, Food Grade Approved Lanolin grease. It is made from a pure high technical grade anhydrous lanolin, food grade approved additives and anti-oxidants. It has been especially designed to remainwww.inoxmx.com
that'll have hurtFirst job! Then called in for a new tyre.
£430 ex vat, I didn't think that was too bad. The fronts are nearly new and the other rear is pretty fresh- I got one the same (BKT)that'll have hurt
We can build you one if you like?Can anyone recommend a Scandinavian style tilting grader bucket for this, most importantly with a bolt on wear edge? I like to keep my bucket corners fresh.
Sounds good, please PM a price and the spec you'd recommend for the backhoe! I'm thinking it would be an ideal tool combined with the extendahoe for maintaining tracks etc. I should be fine with the normal grading bucket for ditching?We can build you one if you like?
With it having legs how much use would you get out of itSounds good, please PM a price and the spec you'd recommend for the backhoe! I'm thinking it would be an ideal tool combined with the extendahoe for maintaining tracks etc. I should be fine with the normal grading bucket for ditching?
Any opinions welcome, I don't want to buy the wrong thing.
