Ok, so my new backhoe has a separate valve block thing located away from the main valve block. It has pressure feed from the pump or main valve block or something and a pressure pipe down to the boom activated by a button. The breaker return pipe on the boom then goes straight back to the tank.
I’ve got loads of room under there. Could I just replace this with a cetop manifold (using the existing return to tank and flow from pump) and then have a two way variable service instead? Or maybe even twin auxiliaries?
