Komatsu pc118 excavator and engcon tiltrotator | eBay
Find many great new & used options and get the best deals for Komatsu pc118 excavator and engcon tiltrotator at the best online prices at eBay! Free delivery for many products.
www.ebay.co.uk
" Offered for sale is a 2012 komatsu PC118 excavator and a 2018 Engcon EC214 tilt rotator which has only done about 1500 hours. It’s a full spec tilt rotator set up with full S45 EC Oil top and bottom hitches with a great SVAB control system. Machine weighs roughly 12.5 ton due to the tiltrotator and wider track pads. It has just over 7000 hours but will increase slightly as still in use. It’s been in my possession since august 2020. Since owning it it has been serviced religiously with genuine filters at 500 hour intervals including final drives and has benefitted from a complete hydraulic oil renewal when it was fitted with a genuine brand new hydraulic valve chest and a genuine brand new hydraulic pump by komatsu. It has also had all the pins and bushes replaced in the last 1000 hours where the king post was line bored and bushed as well.
The machine benefits from a generally pretty tidy undercarriage with low houred 700mm track pads. Included In the sale is a complete set of bolt on 500mm rubber road liner pads and bolts. Should the reserve be met the sale will also include the Engcon SK10 grab, the TMK300 shear, the pallet forks and EMA bucket.
The engine is a komatsu own 102hp power house that runs really well and is always on the button to start. Doesn’t burn any oil or water. Also has a nice crisp air-con and a brand new factory refuelling pump.
Some of the body work is a little scruffy but comes with territory on machine that has been used in the woods. but at any point if something was needed it was either replaced or repaired.
CJD services
callum dyckes
12 Lower Brook Meadow
Sidmouth, Sidford
Devon
EX10 9PS "
current bid £4.19 - reserve not met
