Has anyone on here actually bought anything plant equipment wise from alibaba?
There is a guy over the other side of the pond on an equipment forum I like for the bigger equipment, he's just imported a 1.8 ton cab less mini ex and a stand behind mini skid steer from alibaba for work around his own home, the skid has had a couple of small issues ( chucked a track, found tensioner nut was missing and a flat battery, the alternator is there but not wired up? ) but so far the mini digger has been an absolute bargain from what he has been reporting back. his largest problem was how long it took, I think from memory it was six months from order to arriving in the states
Everything has to be taken into perspective, for what you pay for a brand new machine in china with a decent kubota engine, you can't buy a worn out torn up piece of junk in the UK for.
You'll still have problems with the UK one, probably more so. Worn pins, bushes and undercarriage, tired old engine, temperamental electronics, all the things the previous owner knew was to much hassle to sort, in my eyes you take the risk and roll the dice which ever way you go. Sometimes your lucky sometimes less so.
