Tipping skips
Look handy and good price. Local to me and good to deal with.
they're bloody cheap if they're square enough Dylan ... you going for any of 'em ?
on edit ..... they'm not tipping skips ... whatever picks 'em up has to be able to tip them with the forks .. they're fixed to the base frame .... still cheap enough for what they are though ... alright on a tele with fixed forks or a 360 with fixed forks .. might not tip fully on free swinging forks? Be no good on a conventional balance / RT FLT
diggerjones
diggerjones
No I've got 1 that i never hardly use. Thought you were after some.
you're correct Dyl .. but roll forward type ideally ...
those have to be picked up and tipped with/fitted on, the forks
on ebay at 170 quid each ATM
thanks for thinking of me though ..... and those are VERY cheap ... presumably local to you too in Audlem ?
Fms1
Fms1
Richie bros always have a good selection of these tipping ones, most are straight and gwo and less than £100 the ones I’ve won
I missed out on this, was going to use it as gravel cart on drainage jobs, or for having bulk bags of gravel drop into then load out with micro in track barrow etc
boat skip ... tips're a better bet Giles
Not for what I wanted they wouldn’t be, trying to use topping skip with thin sides and all that gubbins underneath as a bedding box be a right pain. Boat skip strong and slide. Lift arm up with bucket to drag it, also drag it off trailer with mini etc. I’ve a few tiling skips for forklift inc one on wheels but no suited to the task I was thinking
