Worn out rake bucket repair
Bought this 5 ton rake out of auction but think they put it down on road and drove lowloader 100 miles
Needs about 5” adding back on
Is there someone who’ll profile something to weld back on or abandon it stick it back in an auction and buy a new rake bucket save the hassle or send it to holiday @V8Druid for him to fix and paint it Brown 😂😘
3 ton rake for comparison
what you give for it ? assume it's MS not hardox .. lot of effort unless mega cheap
Think only viable way will be if I weld it and prep otherwise be too expensive in someone else’s time just need to buy the profiled tips etc
jd6820
jd6820
I wouldn't waste my time personally. I'm bad myself for doing the same thing, buying something cheap then working on it to make it better. Don't think there's a single time it has actually been cheaper when you consider it's still not new when you've finished. I think you'd draw plenty back for it and go and buy a new item. By the time you've spent a couple of hundred in steel, probably similar in time (prep and welding) then consumables, it probably not worth it and the rest of the bucket still has wear associated with the use that wore the tines out in the first place...
T whiting
T whiting
Launch it into euros and get a new one, if your going to repair it I wouldn't get carried away you should be able to weld a bit of bar up the side of the tines rather than trying to build the tips up.
If you send me a template I will cut you some extension pieces.
William127
William127
I'm also in the 'dont waste your time' camp with that. personally I think that's still got a bit of life in it- get some money's worth of work out of it, flog it and replace with new.
Think that would be my approach, use it as it is, or cut out the lower bracing between the tines and weld new in a few inches further up. Make it into more of a rake than a rake bucket.
I have one of those style buckets (how they should be), , it's brilliant👍👍
That’s a good shout
Rob65
Giles, I suggest you give Mayflower Engineering in Sheffield a shout. We used to buy all sorts of profile cut Hardox from them.
I wouldn’t touch it personally, I can’t see how anyone could wear that down so much - I’d just assume it was designed like that?
