A
AusDave
I have three joysticks on my Haulotte with multiple buttons front and rear with rubber covers which are an integral part of the button operation. The rubber bit is easily removable from the switch when you disassemble the joystick which are all common Rexroth brand joysticks as per the photo of mine below. These sticks are common on backhoes, loaders, telehandlers and excavators. You would think a simple and inexpensive wear part like this would be readily available for replacement but no you might as well be asking for unicorn rocking horse excrement
The rubber has a limited life due to usage and uv damage then the little metal bits fall out making them all but unusable. Doesn't anyone else have this problem or is it just me? Are the machines scrapped when the rubbers fail? I asked the Rexroth rep and he suggested new joysticks at $1500 each. It's like buying a new car when the windscreen wipers have perished!
Hope someone else has been down this path and found a source for these rubbers.
