worth a punt anyone??
1674919864916-png.43605
jd6820
jd6820
Definately solid built things, parts would be a concern but you can still get them. A machine that age would have a lot of obscelete parts sadly. Also the cab cut down is a massive no no for me, skid steers are inherantly unstable and things easily get tipped over the back of the bucket so falling objects is an issue too.
was thinking the same .. would it possibly have had a hinged top half for ease of access (for working on) and it's not been put back on at some point ... wouldn't be a difficult task to create summat out of 502 box to replace it though
looking at it it all seems to be straight forwards mechanical stuff
" Starts and drives fine Boom won’t move Suspect pump issue " ... presumably a separate pump for the hyd functions then, from the drive pump(s)? .... any ideas, you fellas that seem to know these - I'd never heard of 'em ... cheapo skiddy'd be a handy weapon and they'm never cheap
jd6820
jd6820
Yeah lift hydraulics are often separate to the drive. Think they’d be unusable if it wasn’t. Like you say simple enough. The cab would normally pivot up out of the way to give access to all the valves and pipe work underneath.
I’d be betting a problem with the auxiliary hydraulic pump or control valve interlock if it has one fitted.
dead man ?? would that be 4 motors or chain between fronts/rears from the one motor visible in the pix? :unsure:
jd6820
jd6820
Those look to be drive motors at the front wheels can’t see a chain box but I’m guessing a motor per side or at least the newer Thomas loaders are chain driven on each side by one motor per side.
K
keith
hatefull thing a bit like bobcat to drive ,shite.the cab was cut down to clean out chicken sheds.
When I was on the land we had 80,000 battery hens. There was a contractor from north of Boston, Peter Pell, who had a much bigger one. He‘d totally removed the frame for mucking out, and had a massive lightweight bucket. He used to drive into the bottom of the sheds where the cr#p dropped through, and at every crossbeam he ducked his head to one side. I asked him if he’d ever got it wrong, he said “only the once”. Stuck in his mind after that, along with some big splinters from the crossbeam.
