Justme
pulling forward it will.With brakes correctly adjusted the tow tube should not hit the end stop!
Not true.When the damper is totally buggered the force of the slowing trailer can overwhelm the damper to the point when it allows the tube to fully retract, this is when the coupling head bangs against the body. You've also to remember that when the tube is fully retracted you have no brakes on the trailer at that point as its now in what would be the position for when your reversing ie no breaks applied so you can reverse up hills ect.
As I said gas ram working but oil damper not.On the old damper, when I pushed in the hitch with my thigh it would slam back out.
The newly fitted one smoothly returns out.
Not true.think Mick meant the coupling'd not strike the body with the brakes correctly adjusted - i.e. limited rearward travel .... as you rightly say, with the coupling against the delta body, you have no brakes operating![]()
so with the coupling hard against the delta body, what is doing the pushing on the brake rod/cables/linkages ?????Not true.
Full braking will still happen with the hitch fully compressed.
Auto reverse happens in the hub and not affected by the hitch travel.
If its at full travel the brakes are fully applied.so with the coupling hard against the delta body, what is doing the pushing on the brake rod/cables/linkages ?????
I suspect that Justme is assuming that the brakes are properly adjusted........ which we all know is quite unlikely
If light trailer users didn't take the piss on maintenance then we wouldn't be facing the inevitable MOT![]()
Our fourteen foot Ifor had the damper fail and it behaved exactly as you say Gra, kangaroo-ing to a stop. When we fitted the new damper it behaved perfectly, even before we adjusted the brakes, which weren’t far off right anyway.if the damper is burgered (and the brakes are way out of adjustment) the hitch bangs against the front of delta mount under braking and the rear when taking off again ... if the brakes are adjusted well, the brakes come on with a bang, trailer stops abruptly and then it bangs against the rear of the delta mount and usually kangaroos to a halt
Not true. It’s only Friday.Well that got us through the week![]()
