Kubota oc95e engine
Russell
I'm selling my Kubota oc95e single cylinder air/oil cooled diesel engine. It has electric start and I think a one inch key way shaft.
It starts from cold easily and will run all day on very little diesel, I've never burnt more than 2-3 litres. However It does not like starting from warm.
It gives a bit of black smoke at max throttle/revs but no smoke below this.
The original fuel tank is not included but I do have a plastic one and filter I can sell with the engine.
spares or repairs
Offers
Russell
If shipping is required let me know address and I'll get a quote. Will probably be £70-£100
Russell
£300?
The dumper it came off had 800 hours on the clock. I pulled it apart and the bore looks good with the crosshatchings , no idea how to spell that, still clearly visible. I assume it's fueling related but have no knowledge on diesels. I set the valves a while back and replaced the glow plug. The engine is fully assembled but will need gaskets and a repair of some sort
Not a chance, £100 max on eBay as non runner. Dozens of them kicking around breakers yards from fridge wagons.
Ah bugger doing a quick google for one and found this haha
Anyone know the exhaust gasket size for an oc95-e need one for mine but left it at the yard so can’t measure it.
That looks almost the same as the Yanmar Lxx series (and the chinese copies).
That might give you some options depending on your nearest parts place.
