Kubota with Tiltrotator
Probably over thinking it abit.. there is naff all between most of the 5/5.5/6/6.5 ton machines, generally all the same bucket sizes, mostly same power and the reach can be sorted by specified dipper lengths, you really need seat time in any of them and pick the best one to operate as that’s what really counts!
I believe
ET65 is 6.5t
Tak 370 is 6.7t
So these 2 must belong together
Tak 260 and Kub kx57-4 are 5.5/5.7 ton
which is fair bit lighter - big arse and extra counter weight on the ET65 which made me think it would suit à tilty rather well.
I had 15mins on a kubota KX57 with a r2 on sandwich setup - gripper - scandi grader and thought it was noddy.... not terrible but not idéal - kx57-4 comes with a longish dipper as standard which won't of helped.
I suppose yes it would be useful to compare kx57-4 and 260 against 370 and ET65 but im pretty sure they would both share the same size tiltrotator so heavier carrier has got to be better 🤷
Purely going off weight can be misleading. If you look at the patch of ground they stand on and the reach and dig depth etc the kx57 tb260 and et65 are likely all in the same class. Yes weights vary and that may with a tilty stand the wacker out on it's own. Worth remembering it could be 6.75 ton with tilty on which on "6 ton class" size tracks might make it heavy on soft going. 370 is in between 6 and 9 ton class but at nearly 8/9 ton price does it not make you consider another 8 tonner.
The biggest thing i notice with my 290 compared to a tb175 is the extra ton and a quarter on the same footprint when its soft going.
Btw all uk spec takis have longest dipper and heaviest counterweight option depending where you get specs from.
I think there is a fair difference between a kx57 and a Et65 to be fair but I hear what your saying.
Got this on hire u55 it’s ok nice and smooth grades well, don’t like the city pads and cab is smaller than my older kx161-3 in space between joystick, I’m a big guy so not problem for most but have to squeeze legs together all day or thighs push on levers and levels feel low down. Comfier abd more room between joysticks on dx10 lol 😂
Anyway u55 off my list now
I know where your heading 😉
I don’t so that’s good but going to try some machines out rather than just follow the Kubota train because that’s what we’ve always had, fancy a go in the jcb 5/6 ton offering
Always wanted a kx57 but if cabs like u55 then no thanks
Give me a buzz if your this way, mines always close by 👍🏼
I had the exact same thoughts on the kubota range @ 5/6 ton , thus why I didn’t buy one!
Hmmmm ......kinshofer have told me that the ET65 has too much tearout for the TR07 and wont supply one for it,which is odd as the literature says ok for 4-7 tons , so they have offered to quote à TR11 which is 320kg versus 200kg of the TR07 😬
Will have to see if ENGCON / STEELWRIST / ROTOTILT will guarantee the EC206 / X06 / or R2 on the W/N 65 🤔 otherwise its a stepup in weight and 2 cylinders and that doesn't sound good and would poss make a 5.7t machine more appealing 🤷
What’s the Kinshofer on the nearly new TB370 posted earlier in this thread?
