I did wonder about the fibreglass quality tbfBe careful of some of the cheap frames are really flimsy. Nice to see it first.
's one thing putting it in the wrong way round briefly, but leaving it in there long term is testing the diode's performance capabilitiesAs much as they cost I would hope that they have a diode in them to stop problems if you inadvertently put it in wrong anyway
just put an insulating strip between the battery and the contactsView attachment 44335
It finally arrived after customs held it up needing xtra forms filling in
What a cluster f**k it is now after Brexit.
Anyhow did we reach a conclusion as to whether reversing the battery would lead to a slow and painful death or not ?
Old post Resurrection. Sonde is on my shopping list, have a buried chamber to locate. Are you using yours with CAT? How you getting on with it please?View attachment 44335
Yes I have one of them… I do find it hard to find the actual end of it though ? Maybe I need more practice.I have one but prefer to use genie on snake to trace stuff, easier to follow from where you are etc than finding sonde as a one off on end of rods
Continues snake has two cable clips to clip genie too etc
Metal detector and camera snake also on the list . Which camera do you have ?If I’m looking for a chamber I use it with my camera snake so I know the end is in the chamber then trace along and signal goes off keep reducing sensitivity changing orientation until you zero in on an area. I’ve also got the c scope metal detector for finding metal lids that are burried etc
It finally arrived after customs held it up needing xtra forms filling in![]()
