Sonde / trace
Seem to be getting ask to sort out more and more issues separating foul from top water - my old sonde died ages ago and although experience makes you fairly handy it would be useful to be able to trace ...I have an old cable detector and genny (if genny still works 🤔)
Is a sonde on coiled fiberglass still the best or the continuous stuff you clip genny to ?
What are you lads using ? What's the best solution (within reason) - won't use it a lot but occasionally.
And where's best to buy it ?
Cheers
We use a sonde as it can go on drain rods so can push through a bit better. On a cobra it doesn't take much to stop it's progress.
We are almost entirely working on poorly maintained council drainage though rather than foul
I looked at these a few months ago good idea especially if you don't need really long runs.
Do they work well?
Yeah, as it's a single point rather than a whole pine it works best with two people. One pushing rods and one scanning as it moves. Otherwise you can spend ages walking round if you don't know what direction the pipe is going
This! You only have to move it a few rods and you loose it on your own I find, especially with the dead zone right over the top of the sonde- much easier to keep tracing it. Cheap (ish) and cheerful (well, as cheerful as you can be wiping the s**t off afterwards)
Thanks for the replies its another sonde on some rods job then, I fancied one of those fiberglass reels but haven’t used them , i thought they would pass through easier but if not wont bother......any recommendations on sondes and where to get one or all much of a muchness ?
If you get a cobra reel don't make mistake I did and get the smaller 6mm one ,way to weak unless really clean ducts or internal.
Handy for stowing on truck etc but that's it.
Only thing to be sure of is that it’s the same frequency as your cat!
Any thoughts ?
sandy2210
sandy2210
just tie the end of a cheap roll of single electic wire to the end of the cobra or rods and let it unroll as you push it through then attach the genny to other end of the of the cable then you can trace it all the way without losing it
Sick of doing that, want a trace reel. Trouble is, every time I look one up and see the cost I change my mind!
