Has my ram lost a couple of inches?
@AHPP
chalk and cheese there though .....you need another skidster to compare with
Cheers. You’ve got 6.5”. I’ve got 6”. Is there anything inside a hydraulic cylinder that could have come loose and be blocking half an inch of travel? My bent rod theory seems pretty unlikely now.
Sherpa arms (is that what they’re called?) are different. What have you got between these two pins? I’ve got 48.25” to my thumb.
It looks to be a fair amount of tip on the forks in the last picture, may be the geometry of the bucket is wrong?
A
AHPP
I’ve still noticed a change though. Harder to slip in and out of the grab now, which ideally wants the plate horizontal.
A
AHPP
that looks bad for tipping angle to me if it was raised it would be nigh on flat.
There’s a noticeable point in the lifting cycle where the self levelling/tipping starts behaving differently. Like a soft notch it passes through. You get a way better tip with the arms higher.
what're your pins and bushes like ?
A
AHPP
Better than that. “Notch” was perhaps a poor descriptor but I’m short on narrative prowess atm. Not been using my brain enough. It feels like it’s supposed to do it anyway.
C
charlie2
it may have a cusion in the ram that prevents hard dead ending the ram it can be felt as the ram slows when reaching it then speeds up leaving it.
A
AHPP
Is something like YouTube the only way to post video on here or is there some way to upload like uploading photos?
upload to youtube and then post link
sobitlama
sobitlama
It is useful to be on this forum. I hope I can also share something else and help.
